Go Back   Hayabusa.oRg > Modifications > Engine and Performance mods
Reply
LinkBack Thread Tools Display Modes
  #21 (permalink)
Old 05-27-2004, 12:06 AM
Top Gun
Group: Members
Default
Quote:
Originally Posted by [b
Quote[/b] (WarBaby @ May 26 2004,04:59)]Haywood - I'll take a quick stab at it. Although nobody ever does it this way with stock cams, stock compression, etc., a "proportional" increase of bore and stroke relative to the stock bore and stroke dimensions is a matter of scaling if the related components (valves and ports) are equally scaled up to match the increased flow demands. By "scaling", I mean a 10% proportional bore/stroke increase in total displacement would yield an approximate 10% power increase: 1300 cc (160 HP) X 10% = 1430 cc (176 HP). A 20% proportional bore/stroke increase: 1300 cc (160 HP) X 20% = 1560 cc (192 HP). As mentioned, it is never done this way but a realistic power estimate depends upon too many variables--cam profile, compression, air/fuel ratios, head mods, revised timing, and so forth. There are many dyno charts on display at various Busa sites that show the results of the myriad "big motor" modifications available. *Such a question...
Thanks WarBaby... I got a million questions just like that one!! And since you liked THAT one so much, here's another... j/k.. thanks again for a great post.
______________________________________
PC3R, BDE Gen3 with carbon fiber can, PAIR removed, BDE PAIR Blockoff plates, LP Carbon Inlay frame sliders, Scorpio SR-i500 alarm, Top Gun undertail.
  #22 (permalink)
Old 06-02-2004, 09:54 AM
Let 'er eat!'s Avatar
120 mph Busa Dirtbiker
Group: Donating Member
Default
This one should be pinned it took me a minute to find it again
'03 Grey/Silver purchased 9-13-03
"feeling the breeze, passing the cars"
  #23 (permalink)
Old 06-05-2004, 10:38 AM
New Recruit
Group: Members
Default
Thanks for the info..... Now i'll just need to spend the next lifetime digesting the stuff.......
May i assume therefore..... the bigger the pipe diametre the better?
Ride SAFE ..... the bike does not like to spend the night in the mechanics.
  #24 (permalink)
Old 06-05-2004, 11:08 AM
Default
May i assume therefore..... the bigger the pipe diametre the better?[/quote]
Not necesssarily. It depends on what kind of power enhancement you want from an exhaust system. If you install tubes that are very large in diameter, you may have great peak power but the low-to-mid range portion of the powerband will suffer because the gas flow velocity will drop severely. It might help if you focus on the part about flow velocity vs flow volume in the original post. It's all about design compromises to achieve a given performance objective.
What you think of me is none of my business.
  #25 (permalink)
Old 06-05-2004, 12:02 PM
Still got love for ya's...
Default
Excellent read... very informative~ Now could you please break it down with little words that I don't have to get out my dictionary to understand~
j/k.. Great post, thanks for the lesson!!
Greg..... '07 Night Train
  #26 (permalink)
Old 06-09-2004, 12:30 PM
New Recruit
Group: Members
Thumbs up
WB--Nice summary and organized well too
That factory cross-over area does look particularly nasty...
2003 Silver/Grey
Rapid vanishing raptor...
  #27 (permalink)
Old 06-10-2004, 08:56 PM
jfksmith's Avatar
Rookie
Group: Members
Default
BY THE WAY, DID YOU STAY AT A COURTYARD MARRIOTT RECENTLY. THAT WAS A MOUTHFUL OF INFO WHICH FOR ONCE IS ALL USEFUL. THANKS FOR YOUR TIME , INPUT, AND DEDICATION TO THE SPORT. WE COULD ALL USE YOU AS OUR PERSONAL SWAMI. TAKE CARE RIDE SAFE................. JOHN
04 BLACK AND PURPLE BARNEY BUSA
NEWPORT, RHODE ISLAND IS HOME
RETIRED THE WHOLE KAWASAKI FAMILY
750,100R,ZX10,ZX11
FINALLY A BIKE TO LOVE AND NOT LIKE...
  #28 (permalink)
Old 06-10-2004, 09:05 PM
atticdog's Avatar
Hayabusa Master
Group: Members
Default
jfksmith i rode my busa the other day in newport to the jobsite
01 Black/Silver, Pyramid DB, speedo healer, EK ZZZ, 19/42, trac 4-6, Corbin seat, 08 gsxr1K forks, radial brakes, 07 gsxr1K wheels, gsxr1K footpegs, boosted!!!
  #29 (permalink)
Old 06-11-2004, 04:58 AM
Default
Thanks for your generous comments folks!
jfksmith:
BY THE WAY, DID YOU STAY AT A COURTYARD MARRIOTT RECENTLY?[/quote]
Not recently.
  #30 (permalink)
Old 06-11-2004, 08:27 PM
Seasoned Pilot
Group: Members
Default
Hes the short way to ask this question .. Warbaby , if you were to buy a pipe set for all around riding and riping up your buds on the hiway... what pipe would you buy? sj
04 black and blue
yosh cams , brocks pipe ,pc3
sml box mod , throttlemiester,
buell pegs, hugger
silverstars , 17/43s , hugger , muzzy fan
DID chain , signal minder
DaveOs extended ecm , brembo master cyl,
pazzo levers , ss b lines , tobin seat,
billet vel stacks , more to come im sure
  #31 (permalink)
Old 06-11-2004, 09:50 PM
Seasoned Pilot
Group: Members
Default
OOPS!!! Just read wbs profile... IMADORK!
04 black and blue
buell pegs, hugger
  #32 (permalink)
Old 06-11-2004, 10:14 PM
atticdog's Avatar
Hayabusa Master
Group: Members
Default
  #33 (permalink)
Old 06-11-2004, 10:15 PM
atticdog's Avatar
Hayabusa Master
Group: Members
Default
  #34 (permalink)
Old 06-16-2004, 06:15 PM
Hayabusa Immortal
Group: Members
Default
Dang thats one DETAILED AND INFORMATIVE post.. Thx for taking the DA to write it !
Something about that full leather look that makes you just want to put your knee down!
  #35 (permalink)
Old 07-12-2004, 01:07 PM
Group: Members
Default
Quote[/b] (WarBaby @ May 25 2004,15:19)]Item # 3 - This is the primary design bottleneck of the factory design. Suzuki uses an "X" collector/crossover which generates substantial turbulence (resistance) as opposed to the BDE merge collector which maintains a more laminar gas flow for reduced pumping losses.
OK, since the X-pipe in the factory design was a bad idea, what would you say about the HMF X they use in there dual systems? *Bad idea or a better design? *Thanks.
ps. Great post also, has alot of people thinking now I would asume.
  #36 (permalink)
Old 07-13-2004, 12:32 AM
TorontoBusa's Avatar
Default
Wow!! Thanks for explaining all that!
I have a sound questions for you I have the full titanium 4:1 pipe, and it works well but sounds to quite, I can't hear it on the highway.
I plan to open up the can and wrap 1/3-1/2 of the internal perforated tube with sheet metal, this should make it sound louder.
If I cover the section near the tip, or near the engine would it have any change in sound??
Thanks in advance
P.S. Any other idea's using my existing can?
Never had a vehicle to fast!!
2000 Blue & Silver Busa w/Akrapovic PC III USB, M-3's
1982 GS1100SZ Katana w/Yosh
  #37 (permalink)
Old 07-13-2004, 02:16 PM
Rookie
Group: Members
Default
WOW, So basicly exhaust velocity and volume will make my bike go faster, cool, OK.
  #38 (permalink)
Old 07-13-2004, 03:51 PM
sageronin's Avatar
Default
Quote[/b] (Orange_Busa @ July 12 2004,18:07)]
Tom ... I have this same question. When the tuner mapped my HMFs, he commented that their X design was an improvement over the stock pipes. After reading your excellent post, I'm starting to get a clue about exhaust now. Thanks much !!
Brian ... your bike is Sweet !!
Life is all about the ride! Lead, Follow or Get Out of the Way!!
DJ aka SageRonin * * * * * * * * "Resistance is Futile."
  #39 (permalink)
Old 07-13-2004, 05:46 PM
atticdog's Avatar
Hayabusa Master
Group: Members
Default
TorontoBusa
is it a BDE gen3?
and how many miles on the pipe?
Mine got abit louder after some miles on it
  #40 (permalink)
Old 07-14-2004, 05:10 AM
Default
Sorry for being slow to respond. For some reason, I haven't gotten email notifications about the last few posts.
OK, since the X-pipe in the factory design was a bad idea, what would you say about the HMF X they use in there dual systems? *Bad idea or a better design? *Thanks.[/quote]
X-Pipes have their place in the scheme of exhaust designs and, on dual muffler systems, they can broaden the powerband (more power below the HP peak). The factory crossover design was probably a cost-induced compromise.
Wow!! *Thanks for explaining all that! I have a sound questions for you * I have the full titanium 4:1 pipe, and it works well but sounds to quite, I can't hear it on the highway.
I plan to open up the can and wrap 1/3-1/2 of the internal perforated tube with sheet metal, this should make it sound louder. If I cover the section near the tip, or near the engine would it have any change in sound?? Thanks in advance
[/quote]
Yes, covering some of the sound-absorbing holes inside the muffler should make it louder.
Tom ... I have this same question. When the tuner mapped my HMFs, he commented that their X design was an improvement over the stock pipes. After reading your excellent post, I'm starting to get a clue about exhaust now. Thanks much !![/quote]
Cross over pipes can be a good thing for dual systems when properly designed and correctly located. I am sure that HMF's design is far superior to the factory X-pipe crossover. This can aid low-to-mid range gas scavenging which creates greater torque. More torque is always a good thing!
If you visualize an exhaust pulse as a colume of gases moving rapidly through the exhaust tubes, it is easier to imagine what is happening inside the exhaust system. Clearly, a gas colume just wants to get out of the exhaust. It has mass and therefore inertia. The fewer restrictions it encounters, the better. Imagine the gas colume having a smooth, tubular path with gentle bends, no collisions with other gas columes, etc. vs. sharp bends, baffles, and turbulence etc.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
(c) 1999-2009 Hayabusa Owners Group
