2000 Hayabusa ecu and rotor upgrade question
gta18
Hi guys!
I am about to open the stator housing on my 00 busa, and want to know if the stator is submerged in oil?
Do I need to drain the engine oil before opening and replacing it?
Thanks!
I believe i is. My feeling is to do an oil change while the fairings are off anyway...
Where'd you get the parts?
-D
It's open to the crankcase but if you keep the bike level like with a stand it will only leak out a little bit. If you have it on the sidestand be prepared for a Valdez class spill!
Got the parts from ebay. 130$ for the rotor and 90 for the ECU.
it leaked a little bit of oil.
Got it done last night and tried the ECUeditor to Unify all the maps and changed the dwell time to 120%.
I think its running much smoother now.
I just don't know how I can tune this manually or do I have to take it to a tuner? I've read that the gen1 doesn't have the autotune function like the gen2 does.
