Yea you have to split cases to do any crank work. More labor. Personally here is my take on your parts goal:
1. Intake cam swap exhaust side with APE adjustable sprockets (The Intake Cam on the Exhaust side may not be reliable as I have seen where the cam lobe sits on the bucket and it doesn't jive with me. Do small Webs or Yosh cams. Degreed right and you will still see 5-8hp gains everywhere in the RPM range (Streetwise) maybe more depending on headwork, etc.
2. Port and polish cylinder head along with a valve job with Heavy duty valve springs (Don't go 65lb springs as those are better suited for cams over 400' otherwise expect more wear/tear on the buckets and the cam lobes)
3. 08 crank swap, i plan on keeping the stock 81mm bore. That would put me at 1340cc displacement, hopefully it will provide a little more reliablility than the 1397 stroker kit while increasing overall HP and performance. (As stated above, might as well do a bore with it since your in it. 1397 or 1441 are reliable and if heating up occurs then spend a little money and time in beefing up the cooling system. Not hard and not expensive.)
4. Send the 08 crank to APE to get lightened, balanced, and removal of the counter balancer gear removed and light weight replacement shaft added.(Higher revs are nice if you are racing at 12k rpms all the time but for a street setup you are going to want TQ and overall quickness from the heavier assy. Removing the balancer is fine but lightening the crank your going to lose the nice TQ roll-on ooomph!)
5. High volume oil pump gear. (Good idea)
6. Carpenter Power Scoops. (Proven to make HP on the dyno but proven to slow the bike down in the 1/4 and beyond. Don't waste your money.)
7. Brocks CT Megaphone Titanium Full Exhaust 17". (Nice choice of course.)
8. ECU flash and custom map/ dyno tuning done. (I like the ECU tuning above piggyback systems like the PC3/PC5. Either way a good tune is necessary.)
9. Considering adding a small 20 shot of nitrous with and underhump set up but i need to do more research on the proper way to set it up along with the right brands and components. I dont plan on spraying alot just in case something bigger and nastier than me is pulling away on a highway. (On a budget? Well I used both Cold Fusion and Dynotune Nitrous kits and for the money are fine. I personally haven't had any issues with either companies [Knock on Wood]. Since you will be using the ECU tune, you can have two live maps. One off nitrous and one that can kick in whenever you want. 20hp will bore you quick though. Go at least 40hp and you will have no issues. I also like running two jets/lines into each intake opening to give the best hit when fogging. I place it a little different than most. I can send pics if you like. I have used jetting for 65hp gains with no issues after a careful tune.)
1Likes
LinkBack URL
About LinkBacks
This is the knowledge that ive been searching for. My eyes hurt from reading sooo many threads
2006 Suzuki Nitrous Hayabusa
Alot of threads on the builds but very little info after the fact and how they run on the street compared to other bikes
I have a reputable shop lined up that will do the port and polish. So my question is with the list of current performance items that I have what should be my next step? I was looking into pipes and found a nice TiForce sumo but I read unless your motor is seriously built the Sumo can actually rob you of a couple ponies in the lower and bottom end.... As always any tips and advice are much appreciated
