Results 1 to 7 of 7
  1. #1
    New Recruit
    Join Date
    May 2011
    Posts
    82
    Default Compression Ratio change cam swap.
    I noticed one of the big differences between Gen 1 & 2 is the compression ratio. If I was going to boost my motor it obviously would be better to keep the lower static CR.
    However until I boost it seems that upping the CR with a header pipe would be a good performance upgrade and take advantage of what the bike already has?
    What kind of performance gains are people seeing from these mods? What is a good cam?
  2. #2
    Hayabusa Immortal
    Commuta_Busa's Avatar
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    Default Re: Compression Ratio change cam swap.
    you've got a big investment to make if you plan on going turbo so it doesn't make much sense to spend money going in the wrong direction.
    if you do choose this path, a little more CR with the right cams will breath more life into the engine.
    2009 Super Streetbike's Top Speed Challenge Winner
    Unlimited naturally aspirated class
  3. #3
    Jay
    Jay is offline
    Seasoned Pilot
    Join Date
    Jan 2003
    Posts
    460
    You need to realize that compression ratio and compression are two different things, as they are commonly used in performance motor talk.
    Compression Ratio being the static measurement of volumes, "Compression" being cylinder pressure.
    You can increase the performance by increasing "cylinder pressure" Compression ratio is one way to do that. Cam timing and duration ( overlap) is another. ( not counting forced induction at this point )
    Raising the C.R. will raise "cylinder pressure", putting a bigger cams in it will lower cylinder pressure.
    So it is all a trade off. As you mentioner, raising compression and adding cams is a good choice and a will probably not raise cylinder pressure.
  4. #4
    New Recruit
    Join Date
    May 2011
    Posts
    82
    Quote Originally Posted by Commuta_Busa View Post
    Understood I put about $50k into developing the TT for my Z06, end result was a 1k bhp car with air conditioning lol. I had everything else NA and supercharged prior to and I am a firm believer in Turbo charging. However I'm not that bored with the bike yet and am still getting a feel for it. Luckily I turn my own wrenches or it would have cost more.
    Quote Originally Posted by Jay View Post
    I am talking about static compression ratio, there is a difference between the Gen 1 & 2 CRs right?
    I figured a thinner gasket would bump my CR up and make a little more power prior to forced induction. As long as there are no piston to valve clearance issues with a little more lift from the cam I thought more power could be squeezed.
    Do you sell a head gasket and cam kit for this mod?
  5. #5
    Call me Liberace!
    ogre's Avatar
    Join Date
    May 2009
    Location
    The Northwest
    Posts
    5,337
    that and about 42cc's of motor make the difference. a lot of other little stuff too, but a point of compression and some more displacement are always going to spice things up
    Thankful for his Friends...
    2006 Raiment White Hayabusa
    Lumen Junkie in Residence
    Why retros are safer than HID kits
  6. #6
    Jay
    Jay is offline
    Seasoned Pilot
    Join Date
    Jan 2003
    Posts
    460
    Gen 1 Specifications: 1999 Suzuki GSX1300R Hayabusa
    Gen 2 Specifications: 1998 Suzuki GSXR750
    This says GSXR750 , but it is a gen 2 busa
  7. #7
    New Recruit
    Join Date
    May 2011
    Posts
    82
    What do you recommend for a cam updgread and smaller headgasket to go with an HMF dual system, and tune?
Similar Threads
  1. Exhaust Cam swap w/ Intake Cam
    By DBLX in forum Engine and Performance mods
    Last Post: 09-12-2014, 11:52 AM
  2. Change Exhaust cam to Intake cam.
    By nitezpeed in forum Gen II Busa Information
    Last Post: 01-15-2011, 04:35 PM
  3. Compression Ratio is...
    By Fastfrog007 in forum General Bike Related Topics
    Last Post: 02-19-2009, 06:26 AM
  4. Gear Ratio Change?
    Last Post: 08-08-2008, 08:07 AM
  5. Cam swap
    By nitrousdog in forum Busa Mods
    Last Post: 01-05-2005, 01:46 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
