New owner here of an '06. I poked around yesterday and noticed the bike doesn't have a Power Commander or TRE. It does have a full 4-into-1 Brocks exhaust and seems to be tuned ok. ECU flashed, maybe? Anyway, is there any real benefit to installing a TRE other than the top-speed de-restriction? Is it worth the cost if I'm not planning on hitting 200mph? If so, is it an easy install and any recommendations? Thanks for any info, and lovin' the boards |
I have a TRE, and added it to smooth out the rough engine at slow speeds. There are some that say this really works and others that say it doesn't. Here is a good one: hesitates-chokes @ 2200 rpm ______________________________________ I have tried, in my way, to be free. 2006 LE "Magic Carpet Ride" |
I have the opposite experience. I figured I'd spend $20 on one of the cheap 555555 TRE's, mainly to say it isn't restricted anymore. It made a very noticeable difference in bike snappiness, idle quality and idle sound. It feels peppier at part throttle due to the extra timing. Doesn't feel any faster overall, but it definitely woke up the bottom end in around town, part throttle situtations, where I considered it "soggy". It is more sensitive to idle speed adjustment now, but since I didn't get one that maintained the neutral feature I'm not shocked.
______________________________________ www.caintmakit.com- like a fencepost to the groin! 02 black Hayabusa / 74 CB550 / 01 CR500 / 04 CRF70 / 69 Lil Indian |
| Quote:
The ignition remains the same in full advanced degrees. What changed is how the ignition moves to advance sooner is what you feel. So, stock "... better top to bottom" comes back as designed for maximum HP/Performance. Do you think the factory is going to sell you a limped out bike or a bike that is the world's most powerful? I think the tre will limit your bikes potential as in "safe to run" missing an analog signal. ![]() Figure it out. |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| TRE VS SMART TRE VS DIY TRE | scooterlord | Engine and Performance mods | 18 | 10-10-2008 11:54 PM |
| TRE | 07vigorblue | Engine and Performance mods | 22 | 03-12-2008 10:04 PM |
| Questions about tre | Ken02busa | General Bike Related Topics | 15 | 05-22-2006 10:31 AM |
| smart tre vs. tre | Fire95Z28 | Busa Mods | 4 | 06-05-2005 11:55 PM |
| TRE Questions | TheBull350 | General Bike Related Topics | 28 | 08-06-2003 10:20 AM |
