Did you use the same shims when you put it back together? If they even touched the valves and you used the same shims without checking the clearance then your valves are hung open.
______________________________________
Steve, Mud, just not late for dinner! Former owner, lost to the lowlife thieves of the world. 2008 Buell 1125R |
Did the valves touch the pistons while getting the timing right?
Speed merchant http://www.hayabusazone.com |
Sounds like you have the cam timing off!
04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit! 92 GSXR 1100/1216 THE BABY I JUST CANT GIVE UP 99 BUSA, SOON TO SEE THE ROAD AGAIN |
Yeah, im just gonna go real slow and hope i get it this time. I dont know why im having such a brain fart ______________________________________ 08 Real Street Turbo Busa - lots of good stuff ![]() 09 Yamaha R1- Soon to be an ama super sport bike ! |
Vlaves are all fine i looked at them. Is there any special procedures with the ape cam sprockets. When i line it up and i put the cam holders on, the intake valves on 1 are open, shouldnt they be ready to open not open.
I don't know about the APE sprockets but the intake cams should be 180 crank degress past fully open, about 90* on the cam. In short the cam lobe should be pointing more or less towards the rear of the engine and the exhaust cam should be pointing the opposite way, with number one on TDC.
Pictures of how you have it sitting now would help to help you.
______________________________________ ![]() 213.7 LSR "things happen for a reason" "The power is just amazing" - Jason 1441 Quit hating, work harder! |
Who press the sprockets on the cams? If you pressed them on, did you follow the instructions,, of where to line up the hash marks in reference to the lines on the end of the cams? ______________________________________
| Quote:
we have done one or one hundred of them like GPW said also bring it to TDC and take a picture of the sprocket end and we should know more GPW you coming to loring next year? ______________________________________
382hp/191 LB torque 202mph toy |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| just install my brocks akien head | flipzpride | Modifications & Aftermarket Equipment | 18 | 07-22-2009 11:56 PM |
| just install my brocks akien head | flipzpride | Modifications & Aftermarket Equipment | 1 | 05-24-2009 08:38 PM |
| Compression Ratio is... | Fastfrog007 | General Bike Related Topics | 7 | 02-19-2009 06:26 AM |
| Brock's alien head install question | dharp65 | Gen II Busa Information | 17 | 11-27-2007 01:08 PM |
| 13:1 compression | Mike.P175 | Engine and Performance mods | 2 | 09-03-2007 09:10 PM |
