| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
Is two batteries a must for a 1397 with the Gen One Starting system or is one big battery going to do the job in the summer heat?? Someone that has actually built one and personally put miles on one please reply.
and the answer also depends on compression...once you exceed 12:1 the need for 2 batteries gets involved. Starter kickback has as much to do with batteries as it does with the guy pushing the button. Keep that in mind.
hi there i will try the ytz14s batt 1st then see how is it. if after trying it cant then i will go for the 24v. when u are using 24, which battery are u thinking of using? |
I just built a preety stroker (everyday rider) which is starting on one bigger battery with 310 CCA 14 AH... I was hoping that would work. Customer wants a 1397 but wants zero starting issues. Schnitz has a 24V kit or Fastbygas does. Thanks for the replies all.
I run 2 batteries on mine. Dont intend on doing too much street riding with it. Its a pain, or you can run a switch so both batteries can stay charged. I dont ride on the street and put it on the charger after 2-3 starts
______________________________________ C4 Racing isSuzuki City Powered Suzuki City BadBoyz Member Proverbs 10:13 - In the lips of him that hath knowledge, wisdom is found. But the rod is for the back of him that is void of instruction. |
Ive been using a 24 volt starting system for 3 years now! As long as you charge the second battery, when the bike is in the garage, it will never let you down! ______________________________________
04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit! 92 GSXR 1100/1216 THE BABY I JUST CANT GIVE UP 99 BUSA, SOON TO SEE THE ROAD AGAIN |
depends on your compression
| no I still can't believe Greg posted this question
if your bike isn't fast, the Cheeseman didn't touch it Johnnycheese Performance Master map making Master turbo and NA builder 512-767-4273 Last edited by Johnnycheese; 06-12-2009 at 06:22 PM. |
I have the ytz14s battery in mine and I have the 12.8 to 1 JE pistons and have never had a problem yet. That is everyday riding for the past 2 months. Hot starts and cold starts and have never had a problem. I was in the same boat as u earlier this year and decided to try out the ytz14s battery and it works great for me!
Throttle Therapy.....The Only therapy I need |
We now have a 340 CCA battery which seems to work very well on the 1531 stroker we are testing it on. Should be overkill for a 1397. PM for details.
I'm interested in how it works. My 1340 is 13.2:1. With a ytz14s (230CCA) it is marginal when hot, but it does spin it without kickback. Even restarts after runs in the stagging lanes it would start. I'd rather it spin just a bit faster. I was thinking about trying a FBG 380CCA. If not, I'll be in the 24 volt camp.
03 AE 2006 PMRA Street E/T Champion 2007 PMRA Street E/T Champion Pipe and stock arm Fat Old man 9.90 @ 139.16 Room for improvement! A bit longer and a bit of motor work 9.36 @ 147.39 |
I started with the YTS14s then went to the FBG battery. The best solution is the 24v. I could kick myself for not doing it sooner. It'll spin the engine right up with hardly cranking needed for the start.
______________________________________ 2009 Super Streetbike's Top Speed Challenge Winner Unlimited naturally aspirated class ![]() |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Question about cam lifts with a 1397 | Batman#1 | Engine and Performance mods | 9 | 03-06-2009 01:48 AM |
| Bike 2007 Istanbul 15-17 Nov. 2007 | Guclu | General Bike Related Topics | 17 | 11-22-2007 07:24 PM |
| Need advice on launching 1397 68 inch bike | badboysbailagnt | General Bike Related Topics | 4 | 04-02-2006 05:31 PM |
| Need advice on launching 1397 68 inch bike | badboysbailagnt | 1/4 Mile | 4 | 04-02-2006 05:31 PM |
| project bike | diesel | General Bike Related Topics | 19 | 06-15-2005 12:17 PM |
