Results 1 to 11 of 11
  1. #1
    Professional Pilot
    Join Date
    Feb 2009
    Location
    Lancaster, PA
    Posts
    565
    Default Clutch and Brake Fluid
    Hey guys, which fluids do you recommend using when replacing these? the brakes are DOT4 correct? is the local bike dealer best place to get this? what about the clutch? I am putting on galfer lines so will be bleeding and replacing all the fluids. Thanks guys
    99 Busa
  2. #2
    MotoGP Wannabe
    BA BUSA's Avatar
    Join Date
    May 2003
    Location
    Santa Clara, California
    Posts
    12,733
    Default Re: Clutch and Brake Fluid
    Dot4 for the clutch and brakes...any auto parts store should carry it
  3. #3
    Seasoned Pilot billyerds01's Avatar
    Join Date
    Dec 2008
    Location
    upstate NY
    Posts
    346
    what he said.
  4. #4
    Banned Permanently By MC Mustang
    Join Date
    Oct 2005
    Location
    One step ahead of the posers!
    Posts
    6,604
    I use Motorex 5.1
  5. #5
    Professional Pilot BiggDaddyBusa08's Avatar
    Join Date
    Jun 2008
    Location
    New Jersey
    Posts
    785
    Images
    +1 the local auto parts store should have dot 4. I got mine from advance auto just down the street from me.
    One more thing never NEVER never mix dot 3 or 4 with a dot 5 fluid.
    the difference is dot3/4 are a petrolium based fluid and dot 5 is a silicone based fluid ya cannot mix those two fluid cuz it will ruin all the rubber hoses and seals if you put the dot5 in a dot3/4 system.
    I have seen people do this and it will work for awhile but once the dot5 runs thru the brake/clutch system then all rubber parts must be replace and all the metal lines must be flushed out with alcohol and then with the correct fluid.
    2008 orange/black (thnx to my wife for picking the fastest color),TiForce full titanium exhaust,"window" rear lowering links and front lowering strap Brocks,clutch mod.,Speedo Healer Cycle Tek air shifter(for drag racing)Roaring Toys extentions 8" ,Airtech 6" extended street tail. best time 9.577 @ 148.40 mph.
  6. #6
    Professional Pilot OUTLAW1300's Avatar
    Join Date
    Nov 2008
    Location
    Omaha, NE
    Posts
    685
    Yes they recommend DOT4 for both. I use DOT4 for the clutch but Motul DOT5.1 for SS brake lines. If you ride fast, gotta be able to stop fast.
  7. #7
    Trouble Makers Inc.
    Mr Bogus's Avatar
    Join Date
    Dec 2006
    Posts
    2,085
    Images
    11
    Unless you know the caveats to dot5 stick with 4
    this is like an oil or type of air in tires thread waiting to happen but DOT 5 is NOT DOT4 and they have some very distinct differences and unless you are a hard core racer with time to work on your bike more often, you are ahead to just stick with the factory recommended DOT4...
  8. #8
    Join Date
    Jun 2009
    Posts
    39
    Dot 3 & 4 and Dot 5 & dot 5.1 do not mix what should go in apart from different boiling points different addictives are in them. The hydraulic fluid is well away from any hot parts & the stock seals are designed for Dot 4 only.
    hydaulic fluid will in time suck in water from any time exposed to air, it is possible to remove this by boiling the hydraulic fluid at 100 deg C.
    If your brakes are going spongy and have lost there snappy sharp feel.. first do quick rough check after a ride check by a quick touch of the brake disc's are all your disc's feeling the same temperature?
    The square profile on the brake seals can become pinched between the cylinder & bore.. if this happens the brakes often stop working..fluid weeps past the pinched seal and brakes begin to feel less then perfect.
    if this happens fit round profile seals less prone to pinching you can pick them up any hydraulic spares shop.
    repeat using dot anything different from dot 4 will not be as good
  9. #9
    Banned
    Join Date
    Dec 2006
    Location
    Alberta, Canada
    Posts
    5,706
    Only DOT 4
    Not DOT 3,
    Not DOT 5.
  10. #10
    New Recruit
    Join Date
    Jul 2009
    Location
    Des Moines, IA
    Posts
    82
    +1 to mike
    Dot 4, and side note, NEVER mix any of them
  11. #11
    Professional Pilot
    Join Date
    Sep 2007
    Location
    Cary, IL
    Posts
    756
    +1 with mike also......only dot 4. tried flushing my front brakes and running a 5, now I have to change all my seals in the calipers, replace the master, and new brake lines cuz my brakes are dragging due to seal swelling. I burn up a set of pads since this mental melt-down about every 700 miles now.
Similar Threads
  1. Change OEM brake and clutch fluid reservoir
    By tonmarchelli in forum Gen II Busa Information
    Last Post: 07-14-2008, 03:51 AM
  2. Brake Pads & Clutch/Brake Fluid Lessons Learned...
    By JINKSTER in forum General Bike Related Topics
    Last Post: 10-18-2006, 01:02 AM
  3. clutch/brake Fluid color etc.
    By Eden in forum Busa problems
    Last Post: 06-25-2005, 08:32 AM
  4. Brake, Clutch Fluid Replacement
    By Stealth_Busa in forum Maintenance and Do-It-Yourself
    Last Post: 10-30-2004, 05:44 PM
  5. Clutch vs Brake fluid
    By Tiresmoke in forum General Bike Related Topics
    Last Post: 04-20-2004, 05:50 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
