| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
you should speak to the person who's doing the porting/head work. Cams and head should be done together. Since your street ridding and looking for longevity I would stick with mild cams.
______________________________________ 2009 Super Streetbike's Top Speed Challenge Winner Unlimited naturally aspirated class ![]() |
By the way I didnt need dual batteries on my 07 when I was at 1397. When I stroked mine to 1540 I had to switch to dual batteries to get it to start.
1540 JE, Ported KWS head, Carrilo Rods, WebCams, Power commander, Hindle pipe, Schnitz Racing PNC-3000 nitrous controller, TRE, NX Piranah 100 shot N2O, WEGO 3, Schnitz Timing retard box, Lock Up clutch, Billet Sprocket cover, MPS air shifter, 13 over Adams swingarm, 16t/41t, HID headlights, Accumen gear indicator , Converti Bars, Tiger tail, Marvic wheels, Brembo brakes, MSD Launch Controller, MSD Shift light
Thank for the info. I decided to get the port job for the head done by Ward Performance since they are local here. I got to talk to Mr. Ward himself today and went over the whole project with him. He said if I should go with the .395"/.378" lift cams with his port and polish but he also said that I would not need the titanium retainers. He said he has never broke the stock retainer on a busa with even higher lift cams........So I guess I havent decided on the titanium retainers yet.......Right now I just need to send the block to APE and the head to Ward performance. Then when my tranny gets back I should be able to start the assembly! On the battery thing I think I will try out the stock battery first and if it gives me any problems I will then upgrade it to the high amp seeing that you didnt have any problems. ______________________________________
Throttle Therapy.....The Only therapy I need |
| Quote:
Second why are you undercutting the tranny, did you have a problem? Third, on your valve job, is he pushing the guides down or leaving them stock height? As for the head gasket, run standard thickness, Do you know witch 1397 pistons you are getting, are they 12.8 to 1 or the 13.1's? Cams are a funny topic, here, im building DnGrumpy's 1441 wright now, and have researched what will drop in. And i have come up with various answers to the question. By far a 378, is a drop in! A 395, some say it will drop in,, and some say no! Im in the process of measuring to see if it will drop in, or not! The ti keeper's are a waste of money if your machinist is moving the guides! Also the oems keeper's last longer! ______________________________________
04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit! 92 GSXR 1100/1216 THE BABY I JUST CANT GIVE UP 99 BUSA, SOON TO SEE THE ROAD AGAIN |
Also if you move the guides now, you can run up to a 425 cam!
| Quote:
You WILL need the 14S battery. You won't HAVE to go dual battery but starting the engine hot on the OEM will not be easy. I tried and it would hesitantly start cold but not hot. I don't think my 385/385 CAMS are over board at all. I wouldnt go more though. Nice rims ______________________________________
Grip it and rip it!
| Quote:
I am undercutting the tranny because I have the motor apart and my second gear was slipping from a bent shift fork. Yes he is pushing the guides down in the valve job. So I guess that is the catch. If you push the guides down then there is no need for the titanium retainers. Havent decided on the thickness of head gasket yet...... Im going with the JE pistons should be 12.8 to 1 Also Mr. Ward said to get the JE piston kit with the Napier rings. Does anyone know what those are and if they are worth it comapred to the standard piston rings JE supplies with the piston kit? ______________________________________
Well if you live in a humid climate, you may need to go with a 24 volt starting system! If it's not humid a lot, a good 14s battery should do the job! While the case are apart, you should get a set of billet shift shafts also! With the guide moved you cam set up is what ever you want! If you do live in a humid climate, i would use the thicker base gasket, you dont want to add compression, by using the thinner gasket! Another note about the keepers, the ti keepers wear out pretty quick,, well not really wear out but the pocket for the valve shim oval's! Also while its apart you might want to look into a set of lower end studs! ______________________________________
I have the billet shift shafts ordered so that when my tranny comes back those along with some other odds and ends will come too. As for the lower end studs I was not thinking I would be putting too much stress on the block to need them. But I will definately look into them. I dont think they are very expensive so maybe I will just get them for more insurance lol. Thank You for all your help! ______________________________________
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Intake Cam Mod question ??? | BusaWhipped | Engine and Performance mods | 6 | 02-22-2009 01:32 AM |
| Busa Lifts | Stonez | General Bike Related Topics | 2 | 03-06-2008 02:32 PM |
| CAM Question | McyMike | Engine and Performance mods | 15 | 01-29-2007 03:16 PM |
| Cam Question | cee-lo | General Bike Related Topics | 1 | 11-16-2003 07:34 PM |
| Question about the factory cam chain tensioner? | OB_KZZ1 | General Discussion | 12 | 08-15-2000 10:25 AM |
