Results 1 to 19 of 19
  1. #1
    big ed's Avatar
    Join Date
    Oct 2006
    Location
    mibalzitch ,CA.
    Posts
    498
    Default keep busa cooler with a lower temp.sensor
    I dont try anything.I just do it!!!.....Wanna try me?
  2. #2
    Hayabusa Immortal
    Commuta_Busa's Avatar
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    Default Re: keep busa cooler with a lower temp.sensor
    you can get the same switch for less from any auto parts store. You need the Honda accord fan switch.
    It doesn't make the bike run cooler. The engine coolant temp is regualted by the thermostat. What this switch does do is turn the radiator fan on sooner at a lower temp and shuts off at a lower temp as well. It can help keep the temps better regulated. The OE sensor waits until the coolant temp is higher before the fan kicks on which means it's got to work that much ahrder to get the temp back down. Then the OE sensor also shuts off soooner which in turn means it'll have to turn on again sooner to control the temps.
    I hope that makes sense
    2009 Super Streetbike's Top Speed Challenge Winner
    Unlimited naturally aspirated class
  3. #3
    big ed's Avatar
    Join Date
    Oct 2006
    Location
    mibalzitch ,CA.
    Posts
    498
    it makes sense but,what year & model honda?
  4. #4
    Hayabusa Immortal
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    I knew that was going to be your next question... unfortunatly I don't know it off the top of my head and my note books are at home. I'll look it up tonight. You could probably do a search and stumble across it in a post some where.
    Quote Originally Posted by big ed View Post
  5. #5
    Professional Pilot bowwow's Avatar
    Join Date
    Jul 2007
    Location
    Louisville, KY
    Posts
    707
    Not to threadjack, but has anyone used the after-market radiator cap? Is it really worth it?
  6. #6
    Hayabusa Immortal
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    I've used a 22psi cap. The only gain is the extra security in knowing that your cooling system would need to reach even higher temps before boil over.
    This isn't always a good idea because it means your whole engine will be overheating. I've gone back to using the OE cap.
    Quote Originally Posted by bowwow View Post
  7. #7
    big ed's Avatar
    Join Date
    Oct 2006
    Location
    mibalzitch ,CA.
    Posts
    498
    Quote Originally Posted by Commuta_Busa View Post
    Ive done a search with no luck....if you can get that info it would very helpful.thanks
  8. #8
    Hayabusa Immortal
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    np I'll check tonight
  9. #9
    Top Gun
    O Holy P's Avatar
    Join Date
    Sep 2008
    Location
    Fort Lauderdale & Daytona Beach
    Posts
    1,424
    I'd like to know as well *subscribe*
    2005 Hayabusa (Sold)
    '95 blk/red z28 396ci
    11.0 @ 122.6mph n/a
  10. #10
    Banned
    Join Date
    Mar 2004
    Location
    Gettyburg,Pa
    Posts
    3,847
    stolen from another board...
    don't remember the year either, but the NAPA part number on the box is FS244. The number on the barcode on the box is R882467.
    The connector is unique to that switch, too, the Busa one won't fit. When I knew the year Accord, I went to a junkyard and clipped one off a wreck.
  11. #11
    Keep On Trucking
    DR1300R's Avatar
    Join Date
    Jan 2004
    Location
    Quad Cities, Il.
    Posts
    8,315
    Images
    Honda Accord' (part number is 37760-P00-003) I think this sensor was used on several years..
    Doyle #11311
    '00 Low Budget Busa
  12. #12
    Hayabusa Immortal
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    I checked through some of my notes last night. Somewhere I wrote down the years (think mid 90's), model (think 6 cyl, 4dr), and everything else. All I could find at the time was the autozone part number Wells TU197.
    As suzuki said it's best to rip the connector off a junker.
  13. #13
    Professional Pilot markiee43's Avatar
    Join Date
    Jan 2009
    Posts
    675
    Images
    30
    1989 to 2005 honda accord radiator fan switch will work
  14. #14
    Join Date
    Jan 2009
    Posts
    675
    Images
    30
    1989 to 2005 honda accord fan switch will work
  15. #15
    Professional Pilot wht_scorpion's Avatar
    Join Date
    Jan 2008
    Location
    Zanesville, Ohio, United States
    Posts
    532
    Images
    Do that accord fan switch fit the 06 busa and will it plug and play or do i have to mod it
    06 Hayabusa RED/BLACK
    Gipro w Tre, K&N air filter, Pair mod, Factory shift kit, Akrapovic full Ti/carbon exhaust, PC III, 3+ Vortex rear sprocket, Galfer brake and clutch lines, Speed Bleeders, R1 throttle tube mod, Titium spark plugs, Tox rear brake reservoir, Speed O Healer, Small Air Box Mod, D3 Grips, Cox Rad Cover, Xentec Hid, GsxrBots's Rim Decals, Muzzy Fan Blade
  16. #16
    Hayabusa Immortal
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,671
    Images
    107
    It's fits fine but the electrical connector has to be swapped. Get a connector off of a junker.
    Quote Originally Posted by wht_scorpion View Post
  17. #17
    Join Date
    Jan 2008
    Location
    Posts
    532
    Images
    thanks
  18. #18
    Rookie 2005Hayabusa's Avatar
    Join Date
    Mar 2010
    Location
    Oregon
    Posts
    133
    I just did the Honda fan switch change and it was pretty simple. Fan turns on at 93 instead of 108 or something like that. I also went to the first honda I saw at the wrecking yard and pulled the right connector off. I think its a fairly standard part in hondas. Anyway when I bought the controller here is the list they gave of cars that use the same control switch. Kinda long but should give you much more options.
    HONDA ELEMENT/PILOT/S2000/ACCORD/CIVIC RADIATOR FAN SWITCH
    HONDA ELEMENT
    year Type liter del. asp. vin designation where used position notes
    2004 L4 2.4 FI N K24A4 Radiator Fan Switch
    2003 L4 2.4 FI N K24A4 Radiator Fan Switch
    HONDA PILOT
    2004 V6 3.5 FI N J35A4 Radiator Fan Switch at Water Passage
    2003 V6 3.5 FI N J35A4 Radiator Fan Switch at Water Passage
    HONDA S2000
    2007 L4 2.2 FI N F22C1 Radiator Fan Switch 93c
    2006 L4 2.2 FI N F22C1 Radiator Fan Switch 93c
    2005 L4 2.2 FI N F22C1 Radiator Fan Switch 93c
    2004 L4 2.2 FI N F22C1 Radiator Fan Switch 93c
    2003 L4 2.0 FI N F20C1 Radiator Fan Switch
    2002 L4 2.0 FI N F20C1 Radiator Fan Switch
    2001 L4 2.0 FI N F20C1 Radiator Fan Switch
    2000 L4 2.0 FI N F20C1 Radiator Fan Switch
    HONDA ACCORD 25TH ANNIVERSARY EDITION
    1996 L4 2.2 FI N F22B2 Radiator Fan Switch 93c
    1996 L4 2.2 FI N F22B2 Radiator Fan Switch at Thermostat Housing 93c
    HONDA CIVIC CX
    2000 L4 1.6 FI N D16Y7 Radiator Fan Switch
    1999 L4 1.6 FI N D16Y7 Radiator Fan Switch
    1998 L4 1.6 FI N D16Y7 Radiator Fan Switch
    1997 L4 1.6 FI N D16Y7 Radiator Fan Switch
    1996 L4 1.6 FI N D16Y7 Radiator Fan Switch
    1995 L4 1.5 FI N D15B8 Radiator Fan Switch
    1994 L4 1.5 FI N D15B8 Radiator Fan Switch
    1993 L4 1.5 FI N D15B8 Radiator Fan Switch
    1992 L4 1.5 FI N D15B8 Radiator Fan Switch
    HONDA ACCORD DX
    2004 L4 2.4 FI N K24A4 Radiator Fan Switch 93c
    2003 L4 2.4 FI N K24A4 Radiator Fan Switch 93c
    2002 L4 2.3 FI N F23A5 Radiator Fan Switch 93c
    2001 L4 2.3 FI N F23A5 Radiator Fan Switch 93c
    2000 L4 2.3 FI N F23A5 Radiator Fan Switch 93c
    1999 L4 2.3 FI N F23A5 Radiator Fan Switch 93c
    1998 L4 2.3 FI N F23A5 Radiator Fan Switch 93c
    1997 L4 2.2 FI N F22B2 Radiator Fan Switch at Thermostat Housing 93c
    1995 L4 2.2 FI N F22B2 Radiator Fan Switch at Thermostat Housing 93c
    1994 L4 2.2 FI N F22B2 Radiator Fan Switch at Thermostat Housing 93c
    HONDA CIVIC DX
    2004 L4 1.7 FI N D17A1 Radiator Fan Switch at Radiator
    2003 L4 1.7 FI N D17A1 Radiator Fan Switch
    2002 L4 1.7 FI N D17A1 Radiator Fan Switch
    2001 L4 1.7 FI N D17A1 Radiator Fan Switch
    1995 L4 1.5 FI N D15B7 Radiator Fan Switch
    1994 L4 1.5 FI N D15B7 Radiator Fan Switch
    1993 L4 1.5 FI N D15B7 Radiator Fan Switch
    1992 L4 1.5 FI N D15B7 Radiator Fan Switch
    HONDA ACCORD EX
    2002 L4 2.3 FI N F23A1 Radiator Fan Switch 93c
    2002 L4 2.3 FI N F23A4 Radiator Fan Switch 93c
    2002 V6 3.0 FI N J30A1 Radiator Fan Switch 93c
    2001 L4 2.3 FI N F23A1 Radiator Fan Switch 93c
    2001 L4 2.3 FI N F23A4 Radiator Fan Switch 93c
    2001 V6 3.0 FI N J30A1 Radiator Fan Switch 93c
    2000 L4 2.3 FI N F23A1 Radiator Fan Switch 93c
    2000 L4 2.3 FI N F23A4 Radiator Fan Switch 93c
    2000 V6 3.0 FI N J30A1 Radiator Fan Switch 93c
    1999 L4 2.3 FI N F23A1 Radiator Fan Switch 93c
    1999 L4 2.3 FI N F23A4 Radiator Fan Switch 93c
    1998 L4 2.3 FI N F23A1 Radiator Fan Switch 93c
    1998 L4 2.3 FI N F23A4 Radiator Fan Switch 93c
    1998 V6 3.0 FI N J30A1 Radiator Fan Switch 93c
    1997 V6 2.7 FI N C27A4 Radiator Fan Switch 93c
    1997 L4 2.2 FI N F22B1 Radiator Fan Switch at Thermostat Housing 93c
    1996 V6 2.7 FI N C27A4 Radiator Fan Switch 93c
    1996 L4 2.2 FI N F22B1 Radiator Fan Switch at Thermostat Housing 93c
    1995 V6 2.7 FI N C27A4 Radiator Fan Switch 93c
    1995 L4 2.2 FI N F22B1 Radiator Fan Switch at Thermostat Housing 93c
    1994 L4 2.2 FI N F22B1 Radiator Fan Switch at Thermostat Housing 93c
    HONDA CIVIC EX
    2004 L4 1.7 FI N D17A2 Radiator Fan Switch at Thermostat Cover
    2003 L4 1.7 FI N D17A2 Radiator Fan Switch
    2002 L4 1.7 FI N D17A2 Radiator Fan Switch
    2001 L4 1.7 FI N D17A2 Radiator Fan Switch
    2000 L4 1.6 FI N D16Y8 Radiator Fan Switch
    1999 L4 1.6 FI N D16Y8 Radiator Fan Switch
    1998 L4 1.6 FI N D16Y8 Radiator Fan Switch
    1997 L4 1.6 FI N D16Y8 Radiator Fan Switch
    1996 L4 1.6 FI N D16Y8 Radiator Fan Switch
    1995 L4 1.6 FI N D16Z6 Radiator Fan Switch
    1994 L4 1.6 FI N D16Z6 Radiator Fan Switch
    1993 L4 1.6 FI N D16Z6 Radiator Fan Switch
    1992 L4 1.6 FI N D16Z6 Radiator Fan Switch
    HONDA CR-V EX
    2006 L4 2.4 FI N K24A1 Radiator Fan Switch
    2005 L4 2.4 FI N K24A1 Radiator Fan Switch
    2004 L4 2.4 FI N K24A1 Radiator Fan Switch
    2003 L4 2.4 FI N K24A1 Radiator Fan Switch
    2002 L4 2.4 FI N K24A1 Radiator Fan Switch
    2001 L4 2.0 FI N B20Z2 Radiator Fan Switch
    2000 L4 2.0 FI N B20Z2 Radiator Fan Switch
    1999 L4 2.0 FI N B20Z2 Radiator Fan Switch
    1998 L4 2.0 FI N B20B4 Radiator Fan Switch
    HONDA ELEMENT EX
    2006 L4 2.4 FI N K24A4 Radiator Fan Switch 93c
    2005 L4 2.4 FI N K24A4 Radiator Fan Switch 93c
    HONDA ODYSSEY EX
    2002 V6 3.5 FI N J35A4 Radiator Fan Switch
    2001 V6 3.5 FI N J35A1 Radiator Fan Switch
    2000 V6 3.5 FI N J35A1 Radiator Fan Switch
    1999 V6 3.5 FI N J35A1 Radiator Fan Switch
    1998 L4 2.3 FI N F23A7 Radiator Fan Switch 93c
    1997 L4 2.2 FI N F22B6 Radiator Fan Switch 93c
    1996 L4 2.2 FI N F22B6 Radiator Fan Switch 93c
    1995 L4 2.2 FI N F22B6 Radiator Fan Switch 93c
    HONDA CIVIC GX
    2004 L4 1.7 FI N D17A7 Radiator Fan Switch at Thermostat Cover
    2003 L4 1.7 FI N D17A7 Radiator Fan Switch
    2002 L4 1.7 FI N D17A7 Radiator Fan Switch
    2001 L4 1.7 FI N D17A7 Radiator Fan Switch
    2000 L4 1.6 FI N D16B5 Radiator Fan Switch
    1999 L4 1.6 FI N D16B5 Radiator Fan Switch
    1998 L4 1.6 FI N D16B5 Radiator Fan Switch
    HONDA CIVIC HX
    2004 L4 1.7 FI N D17A6 Radiator Fan Switch at Thermostat Cover
    2003 L4 1.7 FI N D17A6 Radiator Fan Switch
    2002 L4 1.7 FI N D17A6 Radiator Fan Switch
    2001 L4 1.7 FI N D17A6 Radiator Fan Switch
    2000 L4 1.6 FI N D16Y5 Radiator Fan Switch
    1999 L4 1.6 FI N D16Y5 Radiator Fan Switch
    1998 L4 1.6 FI N D16Y5 Radiator Fan Switch
    1997 L4 1.6 FI N D16Y5 Radiator Fan Switch
    1996 L4 1.6 FI N D16Y5 Radiator Fan Switch
    HONDA ACCORD LX
    1999 V6 3.0 FI N J30A1 Radiator Fan Switch 93c
    HONDA CIVIC LX
    2004 L4 1.7 FI N D17A1 Radiator Fan Switch at Thermostat Cover
    HONDA CR-V LX
    1997 L4 2.0 FI N B20B4 Radiator Fan Switch
    HONDA ELEMENT LX
    HONDA ODYSSEY LX
    HONDA CIVIC DEL SOL S
    1994 L4 1.5 FI N D15B7 Radiator Fan Switch at Thermostat Cover
    1993 L4 1.5 FI N D15B7 Radiator Fan Switch at Radiator
    HONDA ACCORD SE
    1997 L4 2.2 FI N F22B2 Radiator Fan Switch 93c
    HONDA CR-V SE
    HONDA CIVIC SI
    2005 L4 2.0 FI N K20A3 Radiator Fan Switch
    2004 L4 2.0 FI N K20A3 Radiator Fan Switch
    2003 L4 2.0 FI N K20A3 Radiator Fan Switch
    2002 L4 2.0 FI N K20A3 Radiator Fan Switch
    2000 L4 1.6 FI N B16A2 Radiator Fan Switch
    1999 L4 1.6 FI N B16A2 Radiator Fan Switch
    HONDA CIVIC DEL SOL SI
    1993 L4 1.6 FI N D16Z6 Radiator Fan Switch at Thermostat Cover
    HONDA ACCORD VALUE PACKAGE
    HONDA CIVIC DEL SOL VTEC
    1997 L4 1.6 FI N B16A2 Radiator Fan Switch
    1996 L4 1.6 FI N B16A2 Radiator Fan Switch
    1995 L4 1.6 FI N B16A3 Radiator Fan Switch
    1994 L4 1.6 FI N B16A3 Radiator Fan Switch
    HONDA CIVIC VX
    1995 L4 1.5 FI N D15Z1 Radiator Fan Switch
    1994 L4 1.5 FI N D15Z1 Radiator Fan Switch
    1993 L4 1.5 FI N D15Z1 Radiator Fan Switch
    1992 L4 1.5 FI N D15Z1 Radiator Fan Switch
  19. #19
    Join Date
    Mar 2010
    Location
    Oregon
    Posts
    133
    Ok well with the Honda fan switch and Honda fan switch plug my fairing would not go on. It sticks out too far. I ended up breaking off the connector so that was a waste of time. I thought all was lost for a bit then I just soldered the two wires to the two leads coming out of the sensor. Works fine now just it did not go exactly how I would have liked it to go. First time for that.
Similar Threads
  1. Moving air temp sensor to ram air duct?
    By dirty dave in forum Busa Mods
    Last Post: 10-13-2008, 07:35 AM
  2. low temp Fan sensor
    By Bowdoc in forum Busa problems
    Last Post: 12-04-2007, 11:57 PM
  3. Air temp sensor for 99
    By turbojonn in forum Wanted
    Last Post: 08-22-2007, 03:46 PM
  4. temp sensor mod help needed
    By fireblade1 in forum Busa Mods
    Last Post: 07-18-2005, 06:34 PM
  5. intake air temp sensor
    By curbjaw in forum Maintenance and Do-It-Yourself
    Last Post: 06-01-2005, 07:07 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
