Go Back   Hayabusa.oRg > Modifications > Electrical Mods
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 08-27-2009, 03:54 PM
Group: Members
Default 08 HID Retro
I haven’t seen any 08 with this mod so I will tell you how I did it.
I pre-heated the oven to 200 and put the light in for 10 min. pulled it out and pulled it apart with a kitchen knife and razor, the dryer was to keep the glue warm and easy to pull apart. It did take a while to pull apart.
I used a FX-R and TSX projector both with clear lens replacements. I also went with the 6000 D2S bulbs, nice color and not to blue.
After pulling the stock projector out I took a dremel and did some trimming so that I could sandwich the projector in the stock position and be able to use the stock beam adjustments. by sandwiching the projector there it accomplished the washer mod I was going to do anyways.
the top projector I just ran long screws and lock nuts through the housing then aimed it to the stock High beam tape marks I put on the wall then silicone it in place no need for it to move.
this is the finished product, I covered up the holes I cut with a piece of mirror fix sheet I picked up at auto zone. sorry don’t have more pictures of that. I will post pictures of lights a little later. hope this is helpful to someone.
  #2 (permalink)
Old 08-27-2009, 04:02 PM
Group: Members
Default Re: 08 HID Retro
HID Retro-Fit complete
this is the pictures of the lights at night.
  #3 (permalink)
Old 08-27-2009, 05:39 PM
dadofthree's Avatar
Seasoned Beef
Group: Donating Member
Remember your previous thread, you had some final adjustments to make I think. Fantatic job. I'm happy with the stockers on the '08, but HIDs are great
  #4 (permalink)
Old 08-27-2009, 06:01 PM
head east busa's Avatar
Hayabusa Master
BlackJack Champion Space Runner Champion Kirby's Star Scramble Champion Shuriken Challenge Champion Space Rescue Champion
they look really good man That's just a bit much to go through for that though. I'm good with the hid conversion. It sets off your bike really well
  #5 (permalink)
Old 11-03-2009, 04:28 PM
Robinson Crusoe's Avatar
Group: Members
This is one of the nicest mods I've seen so far. Thanks for sharing
I'm thinking of doing the same thing this winter, actually I was already looking at what theretrofitsource.com has to offer..
I have a few questions:
Do you think this mod could be done with preserving the ability to use the stock manual height alignment for both low and high beam?
Did you have a specific reason why you changed the high beam projector? Do you think the standard high beam projector would be good enough when fitted with "just an aftermarket" HID H9?
Can the housing be changed back to standard halogens or did you have to break something that cannot be fixed..
  #6 (permalink)
Old 11-03-2009, 04:34 PM
Hayabusa Master
looks like everything mounted in place I could be wrong. I know Ogre did something similar and kept the bixenon feature as well. By the way if you heat it at 215 for 15 minutes the light should come apart a little easier. and still won't damage anything if I remember right 250 may even be acceptable.
______________________________________
07 black busa the other fastest color
My name is Dave (cookie thats for you man) but I have been known as hey you, and ****** ******,*******,******,and Wop.(don't ask you had to be there)
  #7 (permalink)
Old 11-05-2009, 12:49 PM
carlsbadbusa's Avatar
Seasoned Pilot
Group: Members
Click ClickClick.....BUUUSSaaaaaaa Gone
  #8 (permalink)
Old 11-08-2009, 11:00 AM
Group: Members
yes you could mount both to the stock reflector housing and keep the manual height alignment for both low and high beam, I just cut it off before thinking about it and mounted it inplace. I changed the low beam to the bottom due to size of the housing on the FX-R its to big to fit in the lower position its a dual beam. But I dont even use the High beam setting on the FX-R projector I just set it higher and run it in low beam setting.
You could use a H9 HID in the stock high beam your just not going to get the clean lines and quality of light you get from a HID Projector.
I would have to say after all the cutting you do there's no going back to stock unless you buy another light.
  #9 (permalink)
Old 11-08-2009, 03:45 PM
ogre's Avatar
Speed Freak!
Group: Members
or just replace the high beam projector with a bixenon and leave the factory reflector low beam.
i swear a lot. i'm working on it
An exercise in restraint...
Lumen Junkie in Residence,
pm me for HID retros
  #10 (permalink)
Old 11-08-2009, 05:08 PM
jsjdjn's Avatar
Rookie
Group: Members
Well this inspired me to install my HID kit that has been sitting around for a month now. I have to get the High Beem Bulb exchanged still before I can install that one. Will post pictures tonight.
James
1999 Hayabusa
  #11 (permalink)
Old 11-11-2009, 10:29 AM
Group: Members
Ok, thanks for your input
I've decided to do this mod and will post pics and a write up when I'm done.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
HID Retro-Fit complete lajguess Gen II Busa Information 16 09-09-2009 10:34 AM
Retro Paint Dr.Strangelove General Bike Related Topics 23 09-08-2008 09:27 AM
M4 DUAL BLACK RETRO EXHAUST wwrpres Gen II Busa Information 0 04-09-2008 06:35 AM
Rossi Retro Colors for Assen Flyasbusa1 General Bike Related Topics 11 06-29-2007 09:05 PM
nice future-retro bike WWJD General Bike Related Topics 20 11-19-2005 10:55 PM
(c) 1999-2009 Hayabusa Owners Group
