Re: High Intensity Red Rotating 1157 Bulb
There is no stamp on the bulb and there is no mention of volts on the original packing.
The bulb works perfect when I start it up, then if I drive a couple of blocks it starts to fade.
I tapped this circuit from my modified undertail LED brake/tail lights as a third light. I'm actually using the original turn signal housing as the 3rd light. I attached it to my custom license plate frame and I thought the housing was grounded through circuit. I'm not sure if I had to add a resistor to the circuit or not.
