Results 1 to 15 of 15
  1. #1
    Join Date
    Jan 2009
    Posts
    Default brake light issues
    im doin some work on my cousin's 05, when he got it it already had an aftermarket led rear assy, it only had like 3 bulbs working and no signals, so i recomended him getting a new assy. He did, I installed it and now all is well as far as signals and just the running light, still no brake light. this is the first busa ive messed with, is there a fuse that is specifically for the brake light, or is it possibly a wiring issue. i checked the light assy and the leds for the brake light do light up, so that leads me to think that is an issue on the bike, if there isnt a fuse where does that brake light wire run to so i can possibly rerun a wire, incase the current one is damaged...
    thanks
  2. #2
    Member of P.E.A.
    twotonevert's Avatar
    Join Date
    Aug 2007
    Location
    Tehachapi CA
    Posts
    25,994
    Images
    27
    Default Re: brake light issues
    Welcome to the oRg. My bike had a ground issue when I first got it. Some one hacked the wiring to install LEDs and I had to run a separate ground for my tail light work.
    Do you know God? http://www.lifechurch.tv/
    Its a Jeep thing, you wouldnt understand!
  3. #3
    Join Date
    Jan 2009
    Posts
    i dont believe it to be a grounding issue, because all of the other lights work EXCEPT for the brake lights
  4. #4
    Dear spring....... HURRY!
    redkat05's Avatar
    Join Date
    May 2006
    Location
    Harborcreek, PA
    Posts
    3,288
    well if the LEDs corresponding to the brake light DO work then ya may have a problem with the wire somewhere.
    Posted via Mobile Device
  5. #5
    Join Date
    Jan 2009
    Posts
    Quote Originally Posted by redkat05 View Post
    yea, thats what i was thinking, where to the wires for the brake lights end at, so i could start at that end and not have to completely pull the wires out from that back end to see where they end up, btw where is the fuse panel on this bike?
  6. #6
    Member of P.E.A.
    Join Date
    Aug 2007
    Location
    Tehachapi CA
    Posts
    25,994
    Images
    27
    Fuse panel is located under the left side inner panel, just under the clutch lever/left side controls.
  7. #7
    Join Date
    Jan 2009
    Posts
    Quote Originally Posted by twotonevert View Post
    k, thanks
  8. #8
    thebbbusa's Avatar
    Join Date
    Feb 2005
    Location
    Westerville, OH
    Posts
    1,938
    I bet you have some wires crossed. There should be 3 wires or 6 wires going to your tail light. The stock bike has two bulbs, hence 6 wires, 3 per bulb. One wire is the ground, one is running and the other is brake. Be sure you don't have the brake and running tied together as this will light the board up, but won't give any variation in brightness. I can't remember the colors, and my pic doesn't show all three, but it may help you enough. You won't have the relays, but you do have the wires that I have going to the wire ties.
    I can take a better pick and label the lines when I get home tonight.
  9. #9
    Join Date
    Jan 2009
    Posts
    from what i remember there is a total of 7 total wires coming to the back of the bike, three that are within the connector (black-ground, white-running, red-brake) and 2 x 2 for the turn signals a pos/gnd, i just plugged the ones in the connector together and coming off of the light assy there was a yellow and a blue, i grounded out the grounds that were for the signal and i connected the corresponding colored ones to their turn signal
  10. #10
    Member of P.E.A.
    Join Date
    Aug 2007
    Location
    Tehachapi CA
    Posts
    25,994
    Images
    27
    There should be a wire for the tag light too.
  11. #11
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,544
    See if you can find and download the Gen I manuals. Great schematics
  12. #12
    Join Date
    Jan 2009
    Posts
    it splits after the connector, off of the running light, they are both a constant
  13. #13
    thebbbusa's Avatar
    Join Date
    Feb 2005
    Location
    Westerville, OH
    Posts
    1,938
    Quote Originally Posted by flipcrab85 View Post
    Did you try switching the yellow and blue? Perhaps you have the running on the brake circuit in the light assembly.
  14. #14
    thebbbusa's Avatar
    Join Date
    Feb 2005
    Location
    Westerville, OH
    Posts
    1,938
    Alright, so from the bike to the tailight there is a wiring harness that has 4 wires in it. Two white with black (brake), one brown wire (running), and one black with white (ground).
    So as in the picture above the two (front and rear activator) white wires with black stripes go together and to the brake side, the brown wire goes to the running light and tag light, and the black wire with white stripe goes to ground.
    The turn signal wires each have two wires going to them.
  15. #15
    Join Date
    Jan 2009
    Posts
    Quote Originally Posted by thebbbusa View Post
    cool deal...
Similar Threads
  1. tail light, brake light and turn signal wiring
    By BusaBill in forum General Bike Related Topics
    Last Post: 07-21-2011, 11:46 PM
  2. brake light doesnt light up?
    By daoryder in forum Busa problems
    Last Post: 04-15-2008, 09:29 PM
  3. SD HID light issues
    By Suijuris in forum Electrical Mods
    Last Post: 06-02-2007, 03:20 PM
  4. Issues bleeding rear brake...
    By 1BDAZM in forum Maintenance and Do-It-Yourself
    Last Post: 07-09-2006, 02:25 PM
  5. Brake Light Always On
    By Cowboy in forum Busa problems
    Last Post: 08-01-2004, 03:57 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
