Go Back   Hayabusa.oRg > Performance > Dyno Kings
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 10-05-2009, 08:51 AM
New Recruit
Group: Members
Default turbo dyno question
I was talking to a guy the other day about a reflashed ecu on turbo bikes. He claimed the pc is better, because the intake temp sensor can correct the a/f ratio with the new power commander hub. Has any one seen a hp gain or loss or a change in air/fuel ratio using the temp. sensor on turbo street bikes? My Hahn kit does not have a bung to hook it up but I could weld one on if it will help it during the winter.
Has anyone tested the Hahn kit with Hahns black box Mapper connected and disconnected on a dyno? If I remove it what difference will it make? Hahns mapper is a mystery to me b/c other kits don't use it.
  #2 (permalink)
Old 10-05-2009, 12:36 PM
ogre's Avatar
Speed Freak!
Group: Members
Default Re: turbo dyno question
it's always safer to reflash. piggybacks are like a band aid for fueling, where a reflash or standalone will give you more accurate fueling control.
______________________________________
i swear a lot. i'm working on it
An exercise in restraint...
Lumen Junkie in Residence,
pm me for HID retros
  #3 (permalink)
Old 10-05-2009, 03:01 PM
Rookie
Group: Members
depending on your set up you might be looking at a better fuel system and larger injectors all togerther depending on what came with your hahn kit
'06 Busa
Bazzaz Z Fi;two brother slip on's; K&N air filter
07 Busa
6" extended swing arm;60 wet shot of nx nos
  #4 (permalink)
Old 10-05-2009, 05:56 PM
New Recruit
Group: Members
I have the stage 1 kit with s2000 injectors, this guy is building a kit for his gixxer 750. I just want to know if the air temp sensor make adjustments that are going to gain or lose power or reliability.
  #5 (permalink)
Old 10-29-2009, 02:14 PM
POWERHOUSE's Avatar
Frank
Group: Site Sponsor
First off, the intake air temperature (IAT) sensor DOES NOT do anything with a dynojet hub. For turbos, the dynojet hub in conjunction with a GM map sensor, can "boost reference" and gives you the ability to build a fuel map for higher boost pressures - it is very flexible, and works excellent when the right tuner does the job.
Reflashing the ECU has its advantages, but tuning is not one of them for many reasons. Yes, you can remove limiters, disable the IAT for turbos, change dwell times, increase rev limits, etc. - all good stuff. You are better off tuning with the powercommander and tuning link.
Hahn's black "mapper" box has nothing to do with mapping. The box serves to limit voltage produced by the bikes own map, which if left alone would throw an "FI" code because of boost pressure. If you disconnect it, that is exactly what it will do, unless you put a check valve in the signal hose to the bikes map sensor . . .
Please do yourself a big favor, and get with a local shop that has dealt with turbo bikes and knows what they are doing . . .
Frank
POWERHOUSE MOTORCYCLES
(631)491-6767
  #6 (permalink)
Old 10-29-2009, 02:36 PM
Got-Busa?'s Avatar
Group: Donating Member
Quote:
Do you mind explaining your opinion on this a little more...?
I just want to understand how a PC and tuning link is better...?
CLICK HERE--> *Got-Busa's LSR Project bike*
"TEXAS MILE - 3/28/09: 204.468MPH"
All thanks to Brock's Performance and Johnny Cheese Tuned!
  #7 (permalink)
Old 10-29-2009, 03:55 PM
POWERHOUSE's Avatar
Frank
Group: Site Sponsor
Sure. The problem with ECU tuning is that you have to either go "cell by cell", or block certain sections and make changes. This puts an enormous stress on the motorcycle while you are trying to hold rpm and throttle position using the dyno brake. This is very similar to the PCII powercommanders, which is about three steps back - i.e., using yesterday's technology today. The other negative about ECU tuning is the inability to "read" the ECU - to go back in and look directly at the map you've created and make running changes. You have to save the map, make changes, and reflash every time you do something. For the tuner, this can turn one hour into three. Once you've spent all that time, if you ever have to go back in for any reason, you have no way of seeing what changes were made to the ECU.
When you tune with a Dynojet Powercommander, all changes are made in the powercommander itself, and no where else. You can see what you are doing while you do it and make running changes. You can use their tuning link software to "roll" the bike at various throttle positions while the bike gently goes through rpm, samples A/F, and automatically makes changes to reach the intended A/F target. Much easier on the bike, and more accurate. You can still make manual changes if you wish, but the A/F curves are straighter than anything you can achieve going cell by cell and everything happens much quicker.
Please note that I do flash ECUs all the time, but not for mapping purposes. ECU flashing is very useful, but right now, a powercommander is definately better from this tuner's viewpoint . . .
Frank
(631)491-6767
  #8 (permalink)
Old 10-29-2009, 04:48 PM
Got-Busa?'s Avatar
Based on what you are saying, it's only easier and quicker for you but not better...?
  #9 (permalink)
Old 10-29-2009, 04:59 PM
Johnnycheese's Avatar
Hayabusa Immortal
Group: Members
tuning link sux for mapping espealing for boost bikes
if your bike isn't fast, the Cheeseman didn't touch it
Johnnycheese Performance
Master map making
Master turbo and NA builder
512-767-4273
  #10 (permalink)
Old 10-29-2009, 06:24 PM
POWERHOUSE's Avatar
Frank
Group: Site Sponsor
Quote:
JC:
I mainly use tuning link for off-boost and steady-state areas. I like to get my boost target started early in the high throttle percentage areas, extrapolate the rest to redline, make pulls and manual adjustments. I then go back through and make sure all my off-boost targets are where I want them. I've been tuning over ten years, and I know you have a lot of experience as well. You just do things a little differently - apparently- which I well respect. What "sux" for you might work fine in different hands.
Still don't like that ECU tuning, though (IMHO) . . .
Frank
(631)491-6767
  #11 (permalink)
Old 10-29-2009, 06:40 PM
POWERHOUSE's Avatar
Frank
Group: Site Sponsor
I am saying that FOR ME, it is easier, quicker AND better . . .
Frank
(631)491-6767
  #12 (permalink)
Old 10-29-2009, 11:03 PM
luisitoboost's Avatar
Group: Members
Hey Frank.
Glad to see your name here Fernando from PR
  #13 (permalink)
Old 10-30-2009, 12:09 AM
turbobusa2000's Avatar
Top Gun
Group: Members
It's kinda refreshing to hear someone with a different opinion about the ecu flashing stuff.
2000 Busa Blue and Silver Garrett GT28
JE 1363 Turbo Pistons, Crower Rods, Custom Laminova Water to air intercooler with MegaSquirt Secondary fuel injection system
  #14 (permalink)
Old 10-30-2009, 12:17 AM
B@DA$$08BUS@'s Avatar
Top Gun
Definitely, very good info being passed around here.
Posted via Mobile Device
  #15 (permalink)
Old 10-30-2009, 07:14 AM
Hayabusa Immortal
Group: Members
JC:
sux as in if you are still going back to clean up areas why waste a step
and yes still not a fan of ecu tuning on turbo bike for ecu mapping due to it is you can not load and test at the same timed
Master map making
512-767-4273
  #16 (permalink)
Old 10-30-2009, 09:03 AM
Commuta_Busa's Avatar
Hayabusa Immortal
Enemy Shooting Champion
Group: Members
I do agree that not being able to make "running changes" is the downside when you compare ecu editor to a dynojet box. Granted, this means it takes more time to tune with the ecu editor. You're able to make more precise map changes with the ecu editor and all of the additional functionality puts it in it's own league. I would assume that all maps are saved to a harddrive as backup which means you can "see" what the tune is for the ECU at any time. If something goes wrong communicating with a dynojet box you would be out of luck too unless you saved the map to your hard drive.
2009 Super Streetbike's Top Speed Challenge Winner
Unlimited naturally aspirated class
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Turbo Dyno hp turbobusa2000 Dyno Kings 46 01-24-2009 11:06 AM
First Turbo Dyno #s superman Dyno Kings 32 11-02-2008 11:35 PM
need turbo map till i get mine dyno thepushercg Turbo 10 04-09-2008 09:52 PM
Turbo dyno tuning? Maryland. 69ls1 Turbo 7 08-19-2007 12:02 PM
Turbo Busa slams 361 horsepower on the Dyno OB_GSXRboy General Discussion 21 03-18-2000 01:31 PM
(c) 1999-2009 Hayabusa Owners Group
