WOW, someone with knowledge...It's a real challenge to make a system function efficiently AND offer appealing asthetics! This is overly simplified but consider the following variables:
1. Basic design: 4-2-1, 4-2-2, 4-1, or 4-4 design depending on your desired results (each has it's own power characteristics).
2. Equal-length header tubes for consistent power pulses from all cylinders and for ease of tuning/mapping.
3. Primary header tube, collector, and mid-pipe diameters optimized for maximum gas flow velocity AND maximum gas flow volume... a compromise (of one or both) that's difficult to determine and achieve.
4. Mandrel bend construction or cut-and-weld pre-bent tubes. Both are tedious and expensive.
5. Header tube and collector shape, volumes, and location(s) (determines the nature of the powerband).
6. Tube material selection--Stainless, Titanium, Steel, Inconel, each with different weights, weldability, thermal properties, corrosion resistance, and finishing traits (polishing, plating, paint, thermal coating, etc.)
7. Routing of entire system for acceptable clearances.
8. Dyno, street, and/or track testing and tuning/mapping.
9. Strong knowledge of exhaust physics (very convoluted), TIG/MIG welding skills, and $$.
Are you sure you want to undertake such a project?
No one can read the yellow font, dude!WOW, someone with knowledge...It's a real challenge to make a system function efficiently AND offer appealing asthetics! This is overly simplified but consider the following variables:
1. 4 into 2 = 2 into 2 into 1 by means of an H and the - part is only to hold together the 2 tubes and give a place to mount it.
2. Done in thick wall Ti I believe the holes are 2 1/4, so come out and angle then go into 2 1/2 asap. and then make a joining cut to mount 2 into 2 to run into the H, to take it into the Mid Pipes. I take it also H brings it back to 2 1/4 so you can have any aftermarket can on it except a big bird since their 2 1/2.
3. Time to dyno and get a custom map according to what cans were made or selected to go onto it.
4. PowerBand to be great throught it all and were it should count most.(if something like that is possible)
Me I would not mind the above in Ti with 2 carbon fiber Yoshimura Tri-Oval Race Cans... or go with a 2 1/2 into the H and 2 1/2 mid pipes for Carbon Fiber BigBird Cans.
Whats your thought on these types of Systems WarBaby?
