Results 1 to 5 of 5
  1. #1
    New Recruit
    Join Date
    Feb 2006
    Location
    Homer Glen, Illinois
    Posts
    81
    Default
    I've notice some grease and grime accumulation on the bottom of both of my fork legs. i've only got 12.5k and never really wheelied it so should the fork seals be leaking? also when i removed the dust seal (with a screwdriver like a fool) i put a small, 1/3 of an inch scratch in the fork leg. mind you its definitely a scratch not a gouge. i can feel it with my finger nail. can this be buffed if necessary or should i just set it and forget it
  2. #2
    Seasoned Pilot
    Join Date
    Sep 2005
    Posts
    392
    Default
    Fork seals do go out over time with just giving to bumps in the road. It's not uncommon. I've read where people like you have fork seal problems at an earlier age.
    Hopefully your scratch isn't too deep as the seal guides up an down in that area and it might cause problems later with new seals.
  3. #3
    Wag
    Wag is offline
    Evil Demon Busa Rider
    Wag's Avatar
    Join Date
    Aug 2004
    Location
    Rio Rancho, NM
    Posts
    9,770
    Default
    Time to replace the seals. If you live in a dusty area with windy days, it may cause the seals to go out faster.
    As for the scratch, you should get that fixed before you put new seals in. You MAY be able to get away with VERY gently sanding out the scratch with some very ultra fine wet-dry sandpaper. Don't overdo it is all.
    --Wag--
    "Morality is doing what is right no matter what you are told. Religion is doing what you are told no matter what is right. " -- Unknown
  4. #4
    Rookie
    Join Date
    Jan 2003
    Location
    Central Massachusetts
    Posts
    214
    Default
    I had mine done a month ago. Only 12K.
    The dealer said it happens early if you endo or wheelie and it might not be covered.
    I said are you accusing me of stunting? They quickly back down.
    Extended warrantee covered both.
    Bokey
  5. #5
    http://www.youtube.com/us
    Rhythm's Avatar
    Join Date
    Feb 2003
    Location
    Col,OH
    Posts
    7,326
    Default
    Quote Originally Posted by swimmer7946 @ Oct. 12 2007, 4:21 PM
    I've notice some grease and grime accumulation on the bottom of both of my fork legs. *i've only got 12.5k and never really wheelied it so should the fork seals be leaking? *also when i removed the dust seal (with a screwdriver like a fool) *i put a small, 1/3 of an inch scratch in the fork leg. *mind you its definitely a scratch not a gouge. *i can feel it with my finger nail. *can this be buffed if necessary or should i just set it and forget it
    You counldn't do any worse by wet sanding the area using 1200 grit black emery paper. Just be sure to rinse the fork cylinder thoroughy when finished, followed with a good polishing.
    Note:Use a bucket of water and add some murphy oil soap to keep the sand paper wet.
    My .02
    Keep us posted on your results!
    Places I traveled on my Busa.
    Also,New Brunswick, Nova Scotia and Prince Edward Island.
    http://independentconnection.org
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
