Go Back   Hayabusa.oRg > Technical > Busa problems
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 04-10-2002, 10:11 AM
Group: Members
Wink
Has this ever happen to you? During hard braking the engine shut off. The first time this happened (yesterday) I thought maybe a fluke; engine not warm enough but it happened again today. I have a 2K2, 3400miles, with all the goodies without going into the motor or adding turbo or nitros (IE: platuim plug, Yosh exhaust, tre, flapper removal, air box mod, etc..) *
  #2 (permalink)
Old 04-10-2002, 11:36 PM
jwcfbd's Avatar
Hayabusa Immortal
Group: Super Moderators
Default
I'm not trying to sound stupid but are you sure you had the clutch in all the way? It had to be asked.
______________________________________
Laguna Seca 2003
  #3 (permalink)
Old 04-11-2002, 12:22 AM
MET's Avatar
MET MET is offline
Sergeant at Arms
Default
Wow that is one I don't think I heard or read anywhere.
  #4 (permalink)
Old 04-11-2002, 12:33 PM
Narcissus's Avatar
Hayabusa Immortal
Asteroids Champion Breakout Champion Mission To Mars Champion Eskiv Champion Gyroball Champion Mosquito Kill Champion Ghost 2000 Champion Jawashoot Champion Mystery Science Torture 3000 Champion Pop-Up Killer Champion Turkey Shoot Champion jetpacker Champion Jet Pac Stan Champion Rally 2100 Champion Solitaire Champion Virus Champion
Default
Sounds like a bad battery, although being a 2002 it doesn't seem likely. Was it stored for any period of time?
  #5 (permalink)
Old 04-11-2002, 10:21 PM
Group: Members
Default
Thanks for the response. Today I took my bike to Race Tek in Florida..They fixed the problem by adjusting the idling speed. The bike was idling at 800rpm and it should be about 1100..He say that is a glich a TRE and the idling sometime needs to be readjusted after the bikes settles in ... :27
  #6 (permalink)
Old 04-12-2002, 02:55 AM
New Recruit
Group: Members
Default
ahh i was just gona suggest idle speed but i guess u already got that figured!
what is a TRE?
i firstthought maybe someon here was from england or somethin, cuz i thinkthey spelled it tyre..but i thought maybe they just spelled it wrong lol
but i've seen it way to many times for that to be it..so what is it?
thanx
brad
  #7 (permalink)
Old 04-12-2002, 09:19 AM
Group: Members
Default
A TRE is a gismo that tricks the rev limiter into thinking the bike in 5th gear all the time. So you get a strong 1st thru 6th gear.
  #8 (permalink)
Old 05-06-2002, 07:02 PM
Group: Members
Thumbs up
Or, with a little more technicality, Timing Retard Eliminator.
Kinda like the ingenius system that Honda came up with (VTEC) that allows the ECU to change the timing (advance or retard) based on engine RPM and drivetrain speed. Since I ride a Suzuki, and almost always have, I don't know if Honda put this technology into their CBR's or not.
  #9 (permalink)
Old 05-16-2002, 01:53 AM
Big O's Avatar
Physicist Genii
Group: Donating Member
Default
I had the same problem with the quick stop stall. It was the idle speed being too low. If it's at 800 it will stall, at 1000 it doesn't.
Age and treachery will over come youth and skill!
  #10 (permalink)
Old 06-16-2002, 10:37 AM
New Recruit
Group: Members
Default
i've had this happen to me twice already
both times just before a 90 degree turn, drop from 3rd to first, start to ease the clutch out for some grip and the back end slides, look down to see no rpm on the tach, bring the clutch back in, coast thru the turn (with my heart pounding), hit the starter, and back on my way, wasn't as scary the second time, but still crazy!, the way i ride i need power to the ground to corner
as far as idle is concerned, mines at about 1250 now, cuz i turned it up recently, but before that it was at 1100 or so. but i've seen it drop to about 900 when stopped at a light then come back up to 1100.
i noticed someone mentioned the battery, when i got my busa the battery was weak, and eventually it juss died completely, so i took the one from the katana, which was also kinda weak, but once i charged it up held the charge fine, but it still isn't very strong. could this affect the bike while riding?
1999 Suzuki Hayabusa 1300R
1999 Suzuki Katana 750
-Kawasaki High Performance Riding School (2003)
  #11 (permalink)
Old 06-16-2002, 10:09 PM
New Recruit
Group: Members
Default
Curt,
The tip-over switch can cause some probs like this. MotoMan covered this tip-over switch prob in detail and how to correct it.
  #12 (permalink)
Old 06-23-2002, 02:48 AM
New Recruit
Group: Members
Default
where would i find this?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
(c) 1999-2009 Hayabusa Owners Group
