Front sproket nut
elmejor
Did some of you guys  can tell me the size "tool to use" and torque of the front sproket nut. for a '04.
105 ft-lbs torque spec according to the shop manual and if I remember correctly it's a 32mm. I think a 27mm will work on the smaller hex part, but it is preferred, and recommended that you use the bigger 32mm outer hex for removal and installation.
