Alright as you all know, my chain broke and tore up some ####. That was all fine and dandy but now we have a big problem. Got everything all assembled on the stands. Started it up ran it for awhile and Shifted it into gear on the stands...ok it went into gear just fine...I tightened the chain blah blah.
Well I get it off the stands start backing it down the driveway in neautral, pull the clutch in shift and bam it dies...I'm thinking well it may just be acting funny. Did it about ten times sam results each time. I'm thinking what the hell
I check the clutch piston thing fine it got fluid, its been bleed alot but something don't seem right...It doesn't fell like there is much pressure but the piston is moving.
Is there something I am overlooking....Also I had to replace the rod sticking out of the side of the motor. Could it be that when it broke it screwed something else up inside the tranny???
Help Me Please
John
Help Me Please
John
