I have a 2000 Hayabusa with nearly 40k miles...Recently my bike has started giving me a weird overheating problem, but it’s unpredictable. I can ride around and the bike is in the low temp range, it’ll creep up a bit if I sit at a light, but nothing major. However if I really ride the bike hard I notice that the temp guage goes up to the half way mark, but then if I just ride it around at highway speeds it’ll start dropping back down, but then at other times it seems that no amount of highway riding will cool it down, it just stays in the middle, but now if I stop at a light for any significant period of time she will definitely overheat...It’ll go into the red if I don’t shut it off or get moving again. I also notice that the overflow tank is sometimes full and sometimes almost empty...Last weekend while I was riding I stopped at a light and happened to look down and coolant had come out of the overflow tank and drained on the ground.
Any idea what this could be? Could it just be air in the system? If so how did the air get in there, cuz I wasn’t having this problem until recently...I’ve never had a problem at all with my cooling system. I hope it’s not the head gasket...I don’t notice any loss of power, no milkyness in the oil sight glass and no white smoke out of the tail pipe. Maybe the system just needs to be burped or flushed, but I really don’t know what the hell is going on or how to approach it. BTW, it can’t be the thermostat because I don’t run one.
Any help you can provide would be greatly appreciated.
Thanks!
Thanks!
