yeah just did the PC3-USB model recently.
i am gonna check the code number in the morning. i'm too friggin tired right now??
thanks for looking out stunnah.
i wanna ride tomorrow!!!!
c41 fuel pump relay circuit fault.- service manual gives you diagnostic flow chart to verify condition and fix for condition if typical failure. Is fuel pump cycling in key ON position. If not check fuse at fuse block. Behind left inner trim panel where, turn signal fuses are etc... to check Dealer mode for troble codes, just use a paperclip ground two wires togather in white connector (DIAG. CONNECTOR) turn key on, if there is a hard code set it will read at the clock LCD. If there is no codes (C00) start bike run for 4 SECONDS, turn off and see if code is set at LCD. If bike will not run CRANK ONLY FOR 4 SECONDS, check for code at LCD. This is the proper procedure for checking for codes short of having a toggle switch from dealer which does the same thing (SHORTS DIAG. CONNECTOR WIRES TOGETHER.)
