A.B. - ADDICTED TO BUSA
Hey Guys,
I have a problem similar to the one discussed with respect to BusainSD’s bike. Got a small nail in my tire. And from reading the opinions in that regard, having a plug & patch dosent seem to be the best option at any speed over 80 miles/hr. Now very clearly in that case, it isn’t really an option for anyone with a Busa. Did a bit of looking around here in Bombay, and someone told me of a Spray (gel) that can be used to mend punctures caused by small nails. Now I don’t know how reliable this method would be, so I thought I’d just ask you guys for some opinions..
The way its done is -
1.You remove the nail from the tire.
2.You attach the head of the Can as per the threads provided to its release valve, to the valve tube of your tire and fix it on to the valve tube, by screwing it clockwise.
3. That’s it… after this, the can fills the tire with its contents which seal the puncture and also inflates the tire.
4. You are supposed to immediately ride it for a couple of kilometers to see that it has properly sealed the puncture. Then check the air pressure and top up, if necessary.
I don’t know if anyone uses such cans in the U.S. or Europe… but would appreciate a feedback. I Would also like to know if there is any other method to mend a tire puncture successfully, other than the gel and the plug and patch methods
I have only about 1500 Kms on the bike and so, am not too keen to trash the tire, if its not necessary. Moreover, its rather difficult to get a brand new tire for such bikes here. I will have to import it. So that’s another reason for not throwing the tire away, just yet. But then again, if it has to be done, I’ll go ahead and get the needful done. Coz I would rather be safe than sorry. So please do let me know
