1300hemibusa
I have 350 miles on the new busa and last night after a 120 mile ride i'm hearing a strange sound ..The sound is like a popping sound or a gurgle... This happens when you blip the throttle at idle to 2000 to 2500 rpms .. It doesn't do it on acell just on decell. On decel i'm hearing kind of a pop pop pop pop untill it reaches idle again.. If you blip the throttle to 3500 rpms you don't hear it on decell .. This sound is not coming from the mufflers, it seems to be coming from the front of the engine... It does kind of sounds like a exhaust popping on decell but i don't hear it at the back of the bike .. I have not before heard this sound till last night .. The only thing i have done is change the oil before i went out last night ...I did add a little to much oil, it's above the sight glass.. The book said 3.7 of oil and that about what i put in ..Did i put to much oil in causing extra crank case pressure? The engine ran great last night, i was able to hit 180 mph once and a few times i took it up to 140 mph.. I'm worried that i damaged the engine ... Any Input would be great ...Thanks Lee..
