I had this on my 99, so to get rid of this before you ruin your pump, This is due to a dirty fuel filter, So replace it and clean your gas lines all the way to the injectors. The fuel hoses we have are prone to kinking and if the fuel filter is clogged. Both filters, the one on the tank drain and the one inside the pump need to be cleaned and the one in the pump replaced. Then replaced our thin fuel lines with marine fuel lines, which you can get at any marine supplier or
www.westmarine.com You need about 2 ft of fire alco model 350 3/8 inch hose, about $6 total. This will save you a $200 fuel pump and getting stranded on the road. Believe me I was about to sell mine bacause I couldn't get it to run for more than a few miles.
If you don't replace the fuel lines the increased flow from a clean filter will kink the fuel lines and ruin the fuel pump. This is the reason 2001 one and newer have in tank pumps, WHihc eliminate hoses under vacuum.
