bronc3
Bought my '03 new, and have just installed rear tire number nine. I have noticed that where the axle passes through the swingarm there is a steel plate on the chain side between the bearing spacer and the hole in the swingarm, but not on the right side. This plate seems to center the axle. I looked at a friend's '00 and his has a steel plate on each side. Just curious whether anyone else with an '03 has plates on both sides. The fische shows two required for all models, except for the K3, which only requires one (left side). I don't see where the swingarm is any different between the years, and without this plate my axle seems a little sloppy where it passes through the swingarm on the right side.
