Results 1 to 9 of 9
  1. #1
    Top Gun nabusa's Avatar
    Join Date
    Feb 2009
    Location
    Fredericksburg, Virginia
    Posts
    1,194
    Default Head shake and bumpy ride
    I am trying to narrow down what is wrong with my bike. Last year my brother hit a curb and it bent the front rim so hard it popped the front tire. I bought a new front wheel since then. I haven't had time to ride this year but the few times I have I noticed my bike doesn't ride smooth anymore. Bought front rear wheels are new. Both tires are new. Front rotors are new. Forks before my brother hit a curb was new. So I am trying to narrow down what is wrong. The forks do not look bent. The wheel looks straight. Although if I let go of the handle bars it shakes/vibrates a little bit. Would like some input on what might be going on. Also the front forks I lowered them an Inch.
    2002 Hayabusa, Gen2 1340 motor swap
    2008 CBR1000RR
  2. #2
    Member of P.E.A.
    Alien Attack Champion Mahjong Connect Champion Mahjong Solitaire Champion twotonevert's Avatar
    Join Date
    Aug 2007
    Location
    Broken Arrow, Oklahoma, United States
    Posts
    24,389
    Default Re: Head shake and bumpy ride
    Was the new tire balanced?
    Do you know God? http://www.lifechurch.tv/
  3. #3
    Hayabusa Immortal
    Asteroids Champion Busa1166's Avatar
    Join Date
    Jul 2008
    Location
    Miami, Fl
    Posts
    8,898
    Quote Originally Posted by nabusa View Post
    You may need to remove the forks and take a closer inspection. If it was a hard hit you should get your baby naked and inspect it for cracks while you are it. Make sure the upper and lower brackets are ok to. Are the rotors straight
    Name is Manny
  4. #4
    Join Date
    Feb 2009
    Location
    Posts
    1,194
    The tire I have on it now was balanced. The previous one was balanced also. Front rotors are brand new oem ones. And I had the bike completely apart this winter and nothing looked out of the norm.
    2008 CBR1000RR
  5. #5
    Hayabusa Master
    #1busa's Avatar
    Join Date
    Sep 2011
    Location
    east coast
    Posts
    1,527
    What about the bearings in the steering column or the damper?
    When fast wasn't Fast enough...........I bought a Busa!
  6. #6
    Join Date
    Feb 2009
    Location
    Posts
    1,194
    Wheel bearings are new, and steering stem bearing are brand new also.
    2008 CBR1000RR
  7. #7
    Join Date
    Feb 2009
    Location
    Posts
    1,194
    Basically the only thing on my bike that is not new is the frame. The entire front suspension was brand new. When it hit the curb, could have that internally messed up the forks?
    2008 CBR1000RR
  8. #8
    Join Date
    Feb 2009
    Location
    Posts
    1,194
    Ok so I figured out my problem. I put my bike on it's rear stand and I put the bike in gear and let it roll. The tire is not round meaning I can see almost as if it has a lump in it. Tire has maybe 500miles on it. I bought both Q2 tires at the same time and both turned out to be bad. I will stick to other tires from now on.
    2008 CBR1000RR
  9. #9
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    60,325
    Sorry to hear about the tires but glad you got it worked out.
    Robert
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
