Crank it up, remove two wires to clutch switch and run it like normal if it doesn't do it after a few tries it's the clutch switch. the vibration could be making the switch act up and code happen. I had this happen on dyno yesterday and did test and no c40 code.The stock switch the contacts stick sometimes.. here is another test i ran it to redline and rolled off the throttleand let engine do the braking instead of pulling clutch in no code...
LinkBack URL
About LinkBacks
