Results 1 to 10 of 10
  1. #1
    Rookie
    Join Date
    Sep 2005
    Location
    fort worth TX
    Posts
    103
    Images
    Default strange tach speedo problem
    Riding home from work tonight my 2002 busa tach and speedo stopped working and are stuck in one position. The tach is at 3k and the speedo is at 20 MPH. Even with key off they stay in that position. It is weird becasue they are electronic. They should at least drop to zero with power off. Any thoughts on it?
    2010 BMW S1000RR motosport colors, ABS, Traction control, shift assist
    2008 Kawasaki KLR 650 modded for extended off road riding
    2004 Hayabusa limited stage 1 turbo 258 HP at the tire
    2002 hayabusa dry 50 shot nitrous
    2001 Ducati 996 full titanium exhaust, tuned by ferrachi
  2. #2
    Join Date
    Aug 2003
    Location
    Southwestern corner of Indiana
    Posts
    Default Re: strange tach speedo problem
    Your odometer is most likely not working either, and maybe not the other 2 gauges. In fact you may notice the odometer and clock are still on and will drain battery. Just pull the fuse and reinstall it and they will reset. (Be nice if fuses were easier to get to) Hope it helps.
  3. #3
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,197
    You can do that but I would suggest disconnecting the connector on the back clutch side of the cluster and reconnecting it making sure it's good. Doesn't sound like it, but are you running HIDs ?
    Robert
  4. #4
    Stardust83's Avatar
    Join Date
    Jul 2010
    Posts
    42
    I've encounter this problem before. U can try removing the seat and disconnect the power. After connecting should be ok.
  5. #5
    Rookie
    Join Date
    Sep 2005
    Location
    fort worth TX
    Posts
    103
    Images
    Yes, I am running HID lights. I will disconnect the battery for now. I will be out of town for a week. Thanks for the suggestions.
  6. #6
    Rookie
    Join Date
    Sep 2005
    Location
    fort worth TX
    Posts
    103
    Images
    I pulled the battery cable off and put it back on and everything went back to normal. I wonder what caused that to happen? I think it started as I went across a railroad track.
  7. #7
    Member of P.E.A.
    twotonevert's Avatar
    Join Date
    Aug 2007
    Location
    Tehachapi CA
    Posts
    25,919
    Images
    27
    Make sure the pigtail going into the back of the cluster is fully seated.
    Do you know God? http://www.lifechurch.tv/
    Its a Jeep thing, you wouldnt understand!
  8. #8
    Stardust83's Avatar
    Join Date
    Jul 2010
    Posts
    42
    Quote Originally Posted by jacks996 View Post
    I got this problem 2 times. Both times disconnect the power then ok already.
  9. #9
    GM of Haya's in the Hills
    chrisjp's Avatar
    Join Date
    Mar 2006
    Location
    Corry, Pennsylvania, United States
    Posts
    11,639
    thats weird... mine has gotten stuck at 185mph a couple of times.... mabey i should "reset" something too
    2006 LE!!!!!!!!!!!!!!!!
    HMF Dual High Mount with polished cans and vector tips,USB PC3,BMC air filter.
    ESD motorsports chrome G3 plateholder
    Diamond Powersport bar tips,Top Gun Undertail
    Ducati 900SS (retired lol)
  10. #10
    Seasoned Beef
    dadofthree's Avatar
    Join Date
    Sep 2006
    Location
    Barnwell, SC
    Posts
    66,197
    Quote Originally Posted by chrisjp View Post
    But were you in third gear
    Reseat the connector on the cluster unless you just enjoy lifting the battery cable every ride. Then when it continues, disconnect the low beam HID and put the factory bulb back in and see if the problem returns
    Robert
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
