The bike comes with two sets of keys, and attached to one is a small plate that contains the key code. If you happen to have it, that should allow you to get a replacement key. Otherwise, another possible option that I found from a search here on the Org. is to try and release the hump (that will require another search on the Org.) and take that lock to a locksmith to use as a template.
