Hi all,
Need some advice here. Just had my new Busa in for the first 1000k service with a local reputable dealer.Bike was running perfectly before the service but when i picked her up i realised something was amiss.
Idle speed is now a little erratic and there is a definate hesitation & surging at small throttle openings.
There is also a fair bit of popping through the cans on overrun.
Bike is fitted with yoshi r77 slip ons but these were fitted from new.
Gearchange is now clunkier but i suspect that is due to the Shell oil they used - never been a fan.
I contacted the dealer - they stated they only checked the throttle body sync but it was within spec so wasn't adjusted but agreed to have another look at the bike.
I have since been back to the dealer & they have rechecked their work & adjusted the air mixture settings, however the problem remains.
Not sure where to go from here - can this be tuned out through the ECU ?
Disappointing when you shell out best part of $300 and the bike is worse for it.
Going to get a second opinion but any ideas from the experts here would be greatly appreciated.
Cheers,
Muzza.
Cheers,
Muzza.
