headhornet
suzuki2642blue
hi can any one help, iv just got my k4 busa out of the garage after a 6 month winter lay of,and to my amazement theres no brake pressure in both front and rear brakes, its as if the fluids evaporated.last year i replaced the rotors,pads and lines and used 5.1 brake fluid it seemed to take ages to bleed the system but i had pressure, the brakes have allways been poor on the bike ,this is the first time this has happened,any ideas would be much appreciated dave
you probably had air in the caliber. fluid ran down there and thats your problem. unless you had a leak
