Go Back   Hayabusa.oRg > Technical > Busa problems
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 11-26-2004, 08:56 AM
Professional Pilot
Group: Members
Default
Well last saturday fiance went to start my bike like she been doing every saturday for the past 5 1/2 months. Said light was dim, heard clicking noise, but wouldnt start. Im not sure if the busa charging system charges at idle or at speed. But going to get a new battery anyways. Whats the cost of a battery? I figure around $40.00-$60.00. Probably get one at auto parts store or walmart. Which are alot closer to where i live at.
______________________________________
2003 40th ann. Busa
Wolf slipons
Muzzy alum fan
TRE
Puig Double Bubble windscreen
PCIIIR
Scorpio alarm
Backoff brake light Flashing module
Freestylecorp undertail
Powerbronze rear hugger
Mototek front clear blinker lens and rear clear taillight lens
  #2 (permalink)
Old 11-26-2004, 03:31 PM
Professional Pilot
Group: Members
Default
do a search ithink you can get a heavy duty one for 119 bucks .
<!--EDIT|rob t
Reason for Edit: None given...|1101504749 -->
stay off the rear brake!!
  #3 (permalink)
Old 11-26-2004, 04:11 PM
bacharles's Avatar
Korrup~shun!!
Group: Donating Member
Default
A battery for your Busa usually costs about $80 (OEM). You can get the heavy duty one with 235cca for $109 at Schnitz Racing. That's what I did...
I intend to ride this mutha 'TIL THE WHEELS FALL OFF... *(Martin Lawrence)
It's not the Jack you should be worried 'bout... it's the ACE in my hand. *(Petey Pablo)
  #4 (permalink)
Old 11-27-2004, 11:20 AM
Group: Members
Default
Go here
www.motorcyclebatteriesusa.com
They're offering free shipping right now and their prices are not too bad at all
  #5 (permalink)
Old 11-30-2004, 03:57 AM
The Big Red One's Avatar
Hayabusa Legend
Group: Members
Default
The Busa takes a specialty battery...Wal-Mart doesn't carry it......I know, out of curiousity I checked I don't know about automotive type places tho...if you find one locally in a Sears ect let us know
  #6 (permalink)
Old 11-30-2004, 10:16 AM
PaceMaster's Avatar
Default
As we know, some of us have had starter problems..What BA said is right on the money. Get the HD one. It will spin the motor faster and can prevent the dreaded back kick..breaking all kinds of parts..Just ask Jester. Thanks BA.
2001 Blue/Silver
Muzzy Ti 4 into One w/ PCII
Givi Luggage and inch and half bar risers
Switchable TRE 167.8 RWHP's
Coffee Onboard always
  #7 (permalink)
Old 11-30-2004, 10:58 AM
zukracer's Avatar
Default
do they come ready to install or would I also need to get a charger to "prep" the battery? Just recall the dealer mentioning something like this when I got the bike.
My Europe Trip Blog
Thread killer, when I post they seem to die
  #8 (permalink)
Old 11-30-2004, 11:27 AM
Smoke D's Avatar
Group: Members
Post
Hey bs72069,
The Service Manual states that you should rev at 5K rpms to test charger output. The output will be between 13.5 - 15 V. I would think that the problem may have been because you weren't riding it and when your girl started it, it was at idle. That didn't generate enough voltage to keep it charged.
Also make sure the brights aren't on while warming it up.
One other thing, make sure the replacement battery is also a Maintenance Free Battery (I don't think you can by a non-MF anymore) but the charging system is only designed for MF batteries, per Service Manual.
1984 Magna V30 (R.I.P.)
1987 VFR 700 Pearl White
Stock
2004 Busa Black/Purple
Zero Gravity Double Bubble
Scorpio 500i
Removed Reflectors
RX85 Radar Detector
Stealth Paint (To make me invisible at speed)
If your not on a Busa, the view never changes.
  #9 (permalink)
Old 11-30-2004, 12:22 PM
Professional Pilot
Group: Members
Default
Cool thanks guys. Im going to test it when i get home. Ride down the road for a few miles and see what happens the next day. Hopefuly its just has a low charge and after rideing it holds a charge. Anyone use a drycell battery in their bike.
2003 40th ann. Busa
Wolf slipons
Muzzy alum fan
TRE
PCIIIR
Scorpio alarm
  #10 (permalink)
Old 11-30-2004, 09:01 PM
Darden's Avatar
New Recruit
Group: Members
Default
I just picked up and installed a "vector" battery tender. Sixteen dollars at Wal-mart. Just connect the included plug to your battery and plug the charger into the wall 110/120V. It can be manually switched to 1 or 2 amps. It has an electronic monitoring system that will charge your battery when it needs it, float the charge and then completely shut off when the battery is charged. You can leave it plugged in for weeks at a time.
I use it because of the ugly winter months here in St. Louis, Illinois!
'04 LE, &quot;Arrest me Red&quot;
If you expect a kick in the ballz, and get a slap in the face, CONSIDER IT A VICTORY!
  #11 (permalink)
Old 12-01-2004, 10:04 PM
GoldenChild's Avatar
DID HE REALLY SAY THAT?
Default
new battery have in stock $75 tyd
Getting You The Right Stuff The First Time To Keep You Riding Longer
www.cloudninemotorsports.com
cloudninemotorsports@comcast.net
  #12 (permalink)
Old 01-29-2005, 02:19 AM
Group: Members
Default
When you buy a new battery also look into a battery tender, it will add life to your battery and starter and save you lots of headaches
  #13 (permalink)
Old 01-29-2005, 03:54 AM
Red05's Avatar
Default
A battery tender is a good idea. Starting a bike and just letting it idle once a week isn't a good idea. The difference in temp as the engine warms up creates moisture through condensation, and it's best to ride it for a period, getting the bike hot enough too evaporate the moisture. This moisture will corrode the engine internally. You're better off changing the oil and just letting the bike sit, removing the battery and let the battery tender take care of it. Sorry for the
  #14 (permalink)
Old 01-29-2005, 04:12 AM
Rhythm's Avatar
Ride Or Die............
Default
At idle, your bike is using its battery power until you reach over 2k rpm, I believe. Then the "generator" takes over and charges the battery if needed.
Places I traveled on my Busa.
Also,New Brunswick, Nova Scotia and Prince Edward Island.
http://independentconnection.org
  #15 (permalink)
Old 01-30-2005, 09:14 AM
fritch1969's Avatar
Rookie
Group: Members
Default
I picked one up at NAPA, (I think it's an exide) for $60.00
  #16 (permalink)
Old 01-30-2005, 09:54 AM
dbusa101's Avatar
Rookie
Group: Members
Default
I bought a replacement battery at walmart, it wasnt for a busa though it was for a gxxr 750 , but hey it worked and the boys were waiting, 50 bucks, mines a 1397 cc and Im not having any problems
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
(c) 1999-2010 Hayabusa Owners Group
