Hey guys. I got a salvage 95 I'm tring to get running. Just got a new ignition hooked up. All electrical is a go, except the fuel pump. I still have some investigating to do but im at work, so I thought I'd get some thoughts. Fuse is good, kickstand up, tip over sensor good. So i turn the bike on, temp gauge goes all the way up. Hit run switch and I hear the click of the relay, temp gauge goes down to bottom, then I hear another click and that's all. I get power to the relay, but no voltage to the pump. Pump also doesn't come on when hard wired. What ya think, both relay and pump are bad? Oh yeah and the starter turns when I hit the start button.
