Has anyone here had this problem with their K8? Mine has a really noisy clutch on cold start until it gets some oil up and circulating through it I assume. It quiets down some after 20 sec. or so of run time but is still slightly noticable even when warmed up but much quieter then upon initial cold start. It pretty much disappears totally when warmed up when the clutch lever is pulled in. It is not the ticking described in the 199 TSB which I believe is a bolt head hitting the inside of the clutch cover. Just trying to decide whether the noise I hear is an indicator that a bolt(s) is/are loosening and to pull it apart and loctite the fasteners as per the TSB or ignore the noise and see if it gets worse over time. I just picked up the bike used and have only put about 50 miles on it so far given the cold weather---it has 1160 miles on the clock.
thanks, Pat
thanks, Pat
