G geoang Registered Dec 18, 2011 #1 02 busa was riding last night lost first gear then all gears within minutes any help would be greatly appreciated
blk02ws6 Registered Dec 18, 2011 #2 was there any indications leading up to the issue? are you sure its not a clutch issue? its pretty odd to lose the trans completely. can you engage it into each gear and you just have no power? or is it locked in a certain gear?
POWERHOUSE Frank Donating Member Registered Dec 18, 2011 #3 Sure sounds like the countersprocket fell off the output shaft . . . .
G geoang Registered Dec 19, 2011 #5 As I shifted into second gear clutch sliped I slowed down shifted to first as I did lost all gears
POWERHOUSE Frank Donating Member Registered Dec 19, 2011 #6 geoang said: As I shifted into second gear clutch sliped I slowed down shifted to first as I did lost all gears Click to expand... Well, if your drive chain isn't hanging on the ground, I think its time to pull that clutch cover and take a sniff!
blk02ws6 Registered Dec 19, 2011 #7 take the oil filler cap off and have a whiff. dump the oil, and sift through it and see what you find.
