So i have a distribution block that I hooked up using a standard relay. the signal wire to the relay is coming from the license plate light lead. Got it all wired up and accessories work as intended but the fuel pump will not cut on. Unless, I disconnect either the main power from the battery to the relay and reconnect it. Then the fuel pump will cut on and the bike will start. Did various troubleshooting steps, and the ripped everything out of there.
bike would not start.
hooked it all back up and the bike started after i connected/disconnected/reconnected the relay. Now the bike will only start if the relay is connected. I think I broke something. All of the lights and such work as nomal, just the fuel pump doesnt prime...
Any ideas? Im out of them.
