Clutch lever not fully returning out...
Fredyp33
Lately when I ride, I notice after I pull the clutch lever in, it doesn't return fully to the outter position. Sometimes, I have to bump it out, so it will sit the normal distance from the handlebar.
Is it possible to just replace the spring that forces the clutch lever back out? And not have to buy another lever.
Has anyone else had this issue?
Thank you.
I would check the lever,to see if its sticking..wd if needed...u might have air in the system, might need bleeded..but i would stick my finger up under the left fairing in front of the front sprocket,where the clutch slave cyclinder is...u can feel inside of it to see if there is dirt in it...it might be sticking and just need cleaned..
