Hi
I have a problem with my gen2 K8 hayabusa front brakes;
Somehow the front brakes became weaker after a few months. After bleeding (air bubbles comes from the bleeding valve) brakes work fine - but only for a while. I have to bleed it in the every spring and nowadays even twice a summer - it seems to getting worse.
I have aftermarket brake hoses (goodridge) but it doesn't cause this because I had the same problem with the stock hoses too.
It does not leak break fluid.
I have heard the same problem from some another gen2 owners in Finland.
Any ideas what causes this? Where the air bubbles get into the brake fluid?
br, jyka
br, jyka
