Changing Rear Brake Rotors?
pixl8d
Is it much of a pain to do? I've changed pads on cars before and I've seen enough guides to know changing out the pads is something a well trained animal could perform, but my rear brake rotor was recently borked due to a seized piston so I want to replace both the pads and the rotor at the same time. Basically What I'm asking is, is it a pain or is it relatively easy? and more importantly, does anyone have a link for the service manual for an '06?
All you have to do is take the bolts out of the wheel and change the rotors out and then put the bolts back in and make sure they are torqued properly and that should be it.
Sent from my iPhone using Tapatalk
:banana:Not difficult at all.
