ssg_petty_210
My 05 Busa tends to shut off on its own at idle or coming to a stop. I found that the bike idles way to low. What I am trying to do is, adjust the idle of it bringing the RPM's up to 1k to 1200k. The issue I am running into, is I got the idle where I wanted, but when you turn the handle bars to the right the rpms jump up alot and the throttle sticks. I was told by a Kawi rider that with their bikes, there is an rpm adjuster you can adjust by turning the screw and looking at the rpm gauge, and NOT have to adjust the actual throttle cable.
I have been tinkering with the throttle cable, and just cant seem to find the sweet spot that brings the rpms where I need them at idle, and to where the throttle doesnt stick or rpms raise when I turn the handle bars to the right. Do we have a screw we can adjust, or do I just have to keep tinkering with the throttle cable. Please respond as soon as possible. I am on lunch break, and need to have this right within the next hour so I can ride back to work. Please help.
