08 busa clicking
alldog
When my bike is off and in neutral it makes a clicking noise when walking it....when its running it clicks only in neutral.....what could this b?
Chain too tight or out of alignment?
How many miles you got on her? Maybe time for new drive chain and sprocket set.
Got 9000 miles on her and you maybe right bout the chain to tight.....when I had the oil changed a few weeks ago the guy did say he tightened up the chain also
i also vote CHAIN...check it for proper slack per manual specs.
Don't quite understand.... Do you mean when stationary with the engine running it clicks? If this is the case then clearly it is not the final drive chain...
With the engine off or on? If the motor is off then it would be the chain being too tight.
It clicks when you walk it in neutral and if you crank it up and hold the clutch n it makes the same sound....as soon as you let off the clutch the clicking slows down and stops
