Lycan6
Okay so i have a 2002 Busa with about 26K miles. I have a speedo healer and 24v starter kit. Electronically everything else is stock except for leds and hids. I took the bike to the shop to find out why the bike will start in neutral without holding the clutch. i have replaced the swith and they tested the switch. The shop could not find anything wrong. Is it possible that the 24v starting system could cause this or the speedo healer? Does anyone else have or had this issue and if so what was the casue. I would like to get this fixed becasue i do beleive this is causing a false rev on my dynos as the fuel is cutting out just past 10K rpm on two different dynos. Any help would be greatly appreciated.
