If you didn't replace the gasket and add sealer then pop it back off and reseal it. Check to make sure all the bolts are tight 1st. Mine was leaking after I replace the cover, turns out two of the bolts were just a tad loose.
Hint on replacing gaskets.
I usually will use yamabond on the gasket side that touches the cover and a thin coat of vaseline on the other side of the gasket that touches the cases.
This way when you remove the cover in the future the gasket wont tear this trick was learned when I had a slider clutch in a GSXR dragbike. After going through many clutch gaskets from adjusting the clutch an old school guy taught me the trick. No more gasket buying for me.
By a torque wrench or you will be purchasing a helicoil set soonier or later. LOL
