brake lights wont work when applied
hott boi
4wahts up guys,i have a problem with my 09 busa.my brake light are on but when i step or squeeze the brakes my light doesnt brighten up.i check the fuse they are not blown. is there a way to to make them work? plz help thanks
You tried the front and rear brake ? Could be bulb :dunno:
Is it factory or after market ?
Check your rear pressure switch. Mine (Gen1) was doing same thing. I cleaned the connector and fooled with the wires (thought it was a loose/bad wire) And it seemed to fix it. I still check it periodically to make sure still working. So far so good. Hope it helps man
Rockethed using Tapatalk
One switch will be up next to the front brake lever the other switch will be behind the rear set near the rear brake reservoir. First I've heard of the circuit board issue. Good to know.
Have you made any mods that would've effected the brakes (e.g. new levers)?
You said the brake light is on (one might assume you meant the tail/parking light), but could it be that the brake light is actually on due to a stuck switch?
My guess would be a faulty switch or, as aussie said, faulty circuit in the tail light assembly.
