Front brake issues!
cfh
Last night i removed the front tireand had it replaced. I bungied up the calipers to keep the pressure off the brake lines. Now after everything has been put back on i have brakes until i roll a ways then it like it gets air and drops to the bar.pump once or twice and you have brakes again....i never broke any of the lines loose or toke the cap off to allow it to get air...ive sence then tried bleeding and nuthing has changed...as long as you go less than 10 the brakes work great..any advise would be great thanks
Is it losing fluid? Anything odd happen during the dis- or re-assembly?
I know after a re-assembly, if you pried the pads apart to get the caliper back on, you'll get some slack until the pads re-seat on the rotor, but that's only for the first time you apply the brake.
No fluid leaks.....thinking its a rotor. I backed off the calipers a lil bit and can see the right one moving sum.Im pretty shure thats gnna be what it is...thanks for the input tho!!!
