Has anyone had trouble with getting trunk unlocked mine has jammed and I am doing a dyno this weekend and my PCIII is in there? Could someone help me out with a solution to get into without busting my seat cowl up?
loosen the lfet side bolts and remove the under tail or under tray and you should be able to access or at least see what you need to see and mayb pull the latch with some needle nose or a pick. i ve had to do the same thing.
spray some wd-40 on the outside of the truck lock, and on your key, insert the key, and turn it a few times. It could just be that over time the lock mechanism has gotten dirty/gummed up, and this will take care of it. When you get it open, spray some wd40 on the mechanism on the inside, as well.
Now if it is actually physically jammed for some reason, I dunno, cant help you. You may have to take apart the tail.
