my 08' with 11,700 miles has been progressively getting worse when i try firing her up. i got the "rectifier recall" done already so that is ruled out. i had the new battery tested just in case and it was at 12.8 volts. so, the gauges sweep and the fuel pump kicks on but when i hit the ignition button nothing happens. the headlamp will dim out if i hold it steady and that is it with an occasional sluggish starter trying to turn over. i've tried locking out the bars left and right in case the ignition wire was broke(my bike doesn't qualify for this recall), put her in gear, neutral, and wiggled the red and blue ignition wires next to the ignition box on the handle bars to see if that would do the trick.. i am guessing the starter is shot but i was curious if there was a relay that triggers it to rule out the cheap stuff first. i can fire her up here and there when she is on the battery tender or just messing with the key on and off and depressing the button a few times but the starter sounds like it's lagging. when i do get her fired up is okay to ride her or will that cause any further damage? any suggestions would be greatly appreciated. i guess i will be hitting the mountain bike a little harder 'til i get this thing figured out.
