I had problems with a Yamaha bike using car 10w-40 Syntec. The clutch started slipping after about 15,000 after I went with synthetic, and yes I changed the oil about every 3000 miles (which was recommended for that bike). I changed out the clutch plates, and the problem came back a while later.
I switched to a Mobile 1 10w-40 4-stroke motorcycle oil on the following oil changes and the problem lessened. Some car oils seem to do such a good job on reducing friction, they may reduce the friction on a wet clutch.
I've had good luck in the last 17 years of motorcycles with non-syn car and syn motorcycle oils. I only had problem with syn-car oils. That pretty much leaves plenty of choices to go with.
BTW. You'll get a different answer for almost everyone you talk to about post break-in oils. Do what you feel better about. I put syn in my busa and my car at the first oil change. It hasn't hurt the bearings in any of my rides yet.
During break-in, the rings need to seat, and that's about it. Just about everything else in the engine requires a thin coat of oil to keep going. Bearings and gears are made to minimum tolerances from the beginning. They will fail faster if they are not protected with a good oil from the beginning. Waiting a few thousand miles to put in a better oil may add a few thousand miles of more "free play" (AKA slapping and rattling) in the bearings and gears. The slower the wear on these parts, the better.
If you found an oil that works well for your bike or car, stay with it!
<!--EDIT|TruWrecks
Reason for Edit: None given...|1103099641 -->
