Results 1 to 6 of 6
Thread: IAP sensor
  1. #1
    Join Date
    Aug 2010
    Location
    Glasgow ish
    Posts
    39
    Default IAP sensor
    my Busa hates me.......
    Following the weekends merryment whenI stripped the fuel pump and throttle bodies for cleaning and general tlc, re-assembled, checked, rechecked then checked again just in case....(I am getting on a bit...)
    Went to start the bike, it fired up and holy mother!...ran like a bag of spanners, rough does not describe it.....so killed the ignition...checked again, no fuel leaks, all sensors connected, all vacuum holes good, no splits...start again....splutters it's way into like, wont rev, wont idle.....HELP!!
    So this morning Iafter a bit of researching I decided to unplug the IAP senser.....damn thing ran, obviously not perfect but it ran... so tested the sensor and it's dead...voltage does not change at all whatever the vacumm applied.
    Is that how these sensors fail...seemingly fine one day than BANG!!
  2. #2
    Hayabusa Master
    rockethead's Avatar
    Join Date
    Oct 2010
    Location
    wheeling, west virginia
    Posts
    1,978
    Images
    Default Re: IAP sensor
    where is this sensor located ? GEN1 or 2?
  3. #3
    Join Date
    Aug 2010
    Location
    Glasgow ish
    Posts
    39
    It's a Gen 1 - the sensor is mounted to the rear of the airbox and connected to the vacumm tubes which tee off to the fuel pressure regulator and throttle bodies.
  4. #4
    New Recruit Dansch06limited's Avatar
    Join Date
    Nov 2011
    Location
    louisville, ky
    Posts
    52
    Did you figure out the problem you had? I am having same type is issue, and not sure where the "map sensor' is located, the dealer told me that's what it could be after I had him map my ECU for my full exhaust.
  5. #5
    Join Date
    Nov 2011
    Location
    louisville, ky
    Posts
    52
    He actually said it could be dirty throttle bodies or dirty map sensor tube, does anyone have pic of location on gen1 Busa for the map air sensor & the tube for it? Or anyone who can tell me were its located exactly. Thanks
  6. #6
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    13,120
    Images
    There not cheep, new from Suzuki it's over $100
    2013 LIMITED, Little Yellow Short Bus!
    04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit!
Similar Threads
  1. Looking for IAP sensor (boost sensor)
    By Rich in forum General Bike Related Topics
    Last Post: 07-25-2012, 12:37 PM
  2. Bad IAP Sensor?
    By 65Cobra in forum Turbo
    Last Post: 12-08-2010, 05:52 PM
  3. **SPONSORS** I need an IAP sensor
    By turbobusa2000 in forum General Bike Related Topics
    Last Post: 05-30-2010, 12:33 PM
  4. IAP Sensor Mod
    By SnapAttack in forum Engine and Performance mods
    Last Post: 06-19-2007, 08:56 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
