Step 1: Get a sheet or light colored blanket and lay it down on the floor.
Step 2: get another sheet or light colored blanket
Step 3: Take lever, cam, and little PITA bearing and cover yourself with the second sheet or blanket.
I used a razor blade or Xacto blade to help hold the bearing down as you replace the cam. Practice several times without the bearing so you get the feel of it
